Activity Forums VEGAS Pro Record Arm
  • Record Arm
    Posted by Roger Bansemer on December 10, 2014 at 5:33 pm
    I’ve been doing some voice overs using “Arm for Record”
    In the past a box has always come up telling me where the audio will be filed. Now that doesn’t happen anymore and it defaults to a documents directory which is not where I want it.
    How do I arm for record and have it ask me where I want the audio to reside again like it use to?
    Roger
    Roger Bansemer – PaintingAndTravel.com
    Russ Froze replied 11 years, 8 months ago 3 Members · 3 Replies
  • Russ Froze
    December 12, 2014 at 6:16 am
    HI, I’m sorry I don’t know how to reset to the default popup that asks where to put the file. I do know that the recorded files folder setting can be accessed via the project properties under the audio tab half way down is the “recorded files folder”
    Russ Froze
  • Mark Barton
    December 15, 2014 at 10:15 pm
    You must have checked the box not to prompt. I see the setting in the Internal settings tab that you can access by pression the SHIFT key while choosing Options from the Tools menu. I used record for the search filter and circled the entry in the screenshot. Change the setting from TRUE to FALSE.
  • Russ Froze
    December 16, 2014 at 9:12 am
    Thanks Mark, it is nice to have the answer to these simple little things. Especially since it is soooo easy to to dismiss the prompt by accident.Russ Froze
