Activity Forums Apple Final Cut Pro Legacy Reconnectiong original media files to copies
  • Reconnectiong original media files to copies
    Posted by Robb Stan on November 30, 2006 at 4:41 pm
    I don’t know if this is going to make sense, but here it goes.
    My partner made a “selects” sequence then he put that sequence into the viewer and pulled clips from that sequence to make a “final selects” sequence. I can’t figure out how to reconnect the clips in the “final selects” sequence back to the original clips. When I do a match frame in the “final selects” sequence it only takes me back to the original “selects” sequence.
    Is there a way to replace all the clips in the “final selects” sequence with the original media clips instead of the copies from the original “selects” sequence? The only way that I figured out how to do it now is by manually typing in timecodes.
    Robb Stan replied 19 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
