Activity Forums Apple Final Cut Pro Legacy Reconnecting path issues in Final Cut Pro 6
  • Reconnecting path issues in Final Cut Pro 6
    Posted by Elliot Gaynon on September 4, 2009 at 11:23 pm
    Hi-
    I am working a project that requires an extensive amount of reconnecting offline media. Whenever I run a search to find media that needs to be reconnected, all goes well. However, when I re-open the project (doing absolutely no changes whatsoever to the file’s path,), FCP doesn’t remember the file anymore. Does anyone know how to avert this issue…or what may be causing this? Thanks,
    e.
    Elliot Gaynon replied 16 years, 11 months ago 3 Members · 3 Replies
  • Dustin Parsons
    September 5, 2009 at 1:09 am
    Is your Scratch Disk set to the folder your media is in?
    I think if you set your Scratch Disk (found under Final Cut Pro > System Settings…) to the folder your media is in, then FCP will find all the files upon opening the project.
    Mac Pro | Leopard 10.5.5
    2.66GHz Dual-Core Intel Xeon | 4GB Ram
    Final Cut Pro Studio 2 | Avid Media Composer
  • Rafael Amador
    September 5, 2009 at 2:48 pm
    Hi lliot,
    The full path needs to match for not having reconnecting problem.
    Starting by the name of the HD that contents the media.
    Rafael
    http://www.nagavideo.com
  • Elliot Gaynon
    September 10, 2009 at 4:57 pm
    I do as you say, I’m not changing the scratch disks. I am still having to reconnect media files everytime i start final cut pro. Any further ideas on why it won’t remember the path? thanks so much!
    e.
