Activity › Forums › Adobe Premiere Pro › Reconnecting Media… A lot of it. Mass linking possible?
  • Reconnecting Media… A lot of it. Mass linking possible?
    Posted by Evan D. newman on September 25, 2011 at 7:26 pm
    I’m primarily a FCP editor, but am assistant editing on a Premiere Pro 5.5 project.
    Workflow—This is not an online project. We have HD 1 – The main editorial and assistant editorial drive. I organize, she edits. Then, HD 2 – Purely a back up. To enhance the productivity of our workflow, since only one of us can be working at a time, I would like to use HD 2 for my work, then export EDLs, etc, for the editor.
    Problem— The backup drive throws all the media offline, since, I can only assume, the project files reference HD 1’s information and folder name and structure. Everything is identical, but HD 2 throws everything offline.
    My question.. Is there a way for me to connect everything at once like? There are hundreds and hundreds of clips and the ‘one by one’ window prompt I’m greeted with in relinking the media is a waste of time. Is there a function that, like in FCP, one can do a mass reconnect?
    Evan
    James Sehatt replied 12 years, 1 month ago 12 Members · 33 Replies
  • 33 Replies
  • Tom Daigon
    September 25, 2011 at 7:40 pm
    You are one of MANY professionals who in switching from FCP have bumped into this major problem with Premiere Pro. It does not have the same search and connect function that FCP has. I would suggest placing a feature request at this website…but dont do it today. The website is down.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digita / Areca 8tb. raid
    Kona 3
  • Evan D. newman
    September 25, 2011 at 7:51 pm
    Ah, that is disappointing. Thanks, and I will definitely post up on Adobe boards. (I’ll ask for color-coded markers while I’m at it too.)
  • Philipp Hampl
    September 25, 2011 at 8:21 pm
    Throw every single into one single folder! Thats what we coped with that situation- we had over 6000 clips!
  • Angelo Lorenzo
    September 25, 2011 at 10:30 pm
    Generally, if each drive has the same folder/file structure, linking one file will link all the files. I’m on Windows and with external drives sometimes they’re plugged in and assigned a different drive letter which will unlink the entire project.
    I suspect something deeper is going on though. Are you mirroring the hard drives before or after Premiere reads the project for the first time?
    I ask this because Premiere, by default, writes an ID number to the metadata of the file so it doesn’t do things like double conform files if a second copy is brought into the media library (bin). I wouldn’t be surprised if it helps re-link projects as well.
    – Angelo Lorenzo
    – https://FilmsFor.Us Helping you sell your film online
  • Tom Daigon
    September 25, 2011 at 10:32 pm
    Hard drives on Macs dont have assigned letters.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Angelo Lorenzo
    September 25, 2011 at 10:43 pm
    Tom, I was giving that as an example of how often I have to relink media, so I am familiar with his issue regardless of how it may be caused.
    Just a point of clarification.
    – Angelo Lorenzo
  • Tom Daigon
    September 25, 2011 at 10:44 pm
    Sorry! I got bitten when a large project was cut on another MAC, then dumped to a hard drive for transporting, then I dumped it to my raid array. The lack of a search/reconnect function made life hellish 😀
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Angelo Lorenzo
    September 25, 2011 at 10:54 pm
    No worries, I’m sure the web makes me come off harsher than I mean to.
    I kind of what to see how his assets are managed. I believe Premiere matches up a project when you point to one file and it does some lateral searching to other folders around where the project is located. I’ve always success with minimal clicks relinking things.
    – Angelo Lorenzo
  • Tom Daigon
    September 25, 2011 at 10:57 pm
    Its really a bitch when you are working on someone elses project with lots of folders and no familiarity with all the clip names 🙁
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Gary Huff
    September 26, 2011 at 3:01 am
    The only way this turns into a problem is if material is scattered about haphazardly. As Angelo mentioned, if everything is kept together under a main project folder, linking one single file will allow Premiere to find the rest. I do this all the time considering I work on Premiere on both platforms.
    If this is not the case, I would imagine that the organization of the project itself leaves a lot to be desired.
Page 1 of 4
