Activity › Forums › Apple Final Cut Pro Legacy › Reconnecting Media
  • Reconnecting Media
    Posted by Melissa Palmer on January 3, 2009 at 2:29 am
    My harddrive crashed and I lost half of the tapes that I digitized, I copied them back onto the harddrive from a backup drive and was able to reconnect everything in the browser (but only one clip at a time). Unfortunately, I have tried various things, but the sequences in the timeline are still offline. Do I have to go in and reconnect all of those clips one by one as well? I have been able to do it this way, but is there an easier/faster method? Thanks in advance for any suggestions that anyone can give me.
    Melissa Palmer replied 17 years, 9 months ago 3 Members · 3 Replies
  • Rafael Amador
    January 3, 2009 at 7:00 am
    Hi Melissa,
    When you open a project and there is media off-line, FC asks if you want to reconnect the media all at once.
    Rafael
    http://www.nagavideo.com
  • Francois Stark
    January 3, 2009 at 10:01 am
    Highlight a clip on the timeline. Apple-9 shows the clip info. Go to logging. If you don’t see a path to the clip or its filename, it means the project has lost any reference to the file. In this case each clip must be connected individually, and usually it’s a mess.
    If you can see the path and filename, all is well. Close the clip info window. Select multiple clips on the timeline. Right click (or cmd-click) on one of them and select reconnect. The clips should be found automatically. Click connect to finish the process.
    Good luck
    F
    Regards
    Francois
  • Melissa Palmer
    January 4, 2009 at 1:52 am
    Thanks everyone, this has been very helpful!
