Activity › Forums › Apple Final Cut Pro Legacy › Reconnected files keep going back offline- how do I save??
  • Reconnected files keep going back offline- how do I save??
    Posted by May Bolton on April 16, 2008 at 11:49 am
    Hi everyone,
    I’m desperate for some help. I’ll start by explaining the background to my current problem and then the latest problem I’m having.
    A couple months ago I came to work on a FCP project that I hadn’t opened in a while (4-5 months). I would open it and it would load to about 3 or 4 % and then crash. I sought help on this problem and was advised that it might have been a single corrupt clip. Whatever it was, I followed the advice I was given and moved the related files that I had saved in the same place as the project file (all were saved on a small external HD), and moved it to a second external HD therefore breaking the link between the project file and the related media files. Since then I have been able to open the project file offline without any problem and have begun to reconnect the media files from my second external HD.
    I had assumed that if I reconnected the files one by one (while keeping a written log of each clip) then I could just move each media file that reconnected, back onto the original hard drive so that it is back in the same place as the original project file. I had also assumed that the project would now open with all the files reconnected and in place and that I could continue the process of reconnecting until I came across the corrupt clip, that I would then delete.
    Instead of the project file reopening with some of the reconnected files in place (the ones I moved back to the original HD), I am having to start the process all over again. Call me naive but I don’t understand why this is happening. I have only ever had time to do reconnecting in stages over the course of a few days but I keep finding that nothing is saved.
    The last time I tried to open the project file normally it crashed again. I’ve pasted my last crash log below for more information.
    Could someone offer any advice or clarification?
    J
    Final Cut Pro 4.5 HD
    Mac OS 10.4.11
    LAST CRASH LOG:
    Date/Time: 2008-04-07 15:30:28.589 +0100
    OS Version: 10.4.11 (Build 8S165)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Final Cut Pro HD 4.5.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [70]
    Version: 4.5 (4.5)
    Build Version: 2
    Project Name: FCPApp
    Source Version: 4860000
    PID: 270
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Thread 0 Crashed:
    0 …ple.CoreServices.CarbonCore 0x90bb5ab8 FSpMakeFSRef + 16
    1 …ple.CoreServices.CarbonCore 0x90bdf030 CallComponentFunctionCommon + 1044
    2 com.apple.LiveType.component 0x04d54cf4 LTQTCodecComponentDispatch + 3356
    3 …ple.CoreServices.CarbonCore 0x90bdf1cc CallComponentFunctionCommon + 1456
    4 com.apple.LiveType.component 0x04d55228 LTQTImportComponentDispatch + 88
    5 …ple.CoreServices.CarbonCore 0x90bdebb8 CallComponent + 260
    6 com.apple.QuickTime 0x94861fe0 MovieImportDataRef + 80
    7 com.apple.QuickTime 0x9497b464 newMovieFromFileFromComponent + 1044
    8 com.apple.QuickTime 0x949235b8 getNewMovieFromFileUsingImporters + 792
    9 com.apple.QuickTime 0x94922f64 NewMovieFromFilePriv + 756
    10 com.apple.QuickTime 0x949a95f4 NewMovieFromFile_priv + 20
    11 com.apple.QuickTime 0x949a95c8 NewMovieFromFile + 72
    12 …alCutPro.Plugins.QTM Reader 0x03f1ec14 NewMovieFromFileWithGWorld(MovieType***, short, short*, unsigned char*, short, unsigned char*, OpaqueGrafPtr*) + 116
    13 …alCutPro.Plugins.QTM Reader 0x03f2cfcc FileOpenDataCore(KGFileRec*) + 528
    14 …alCutPro.Plugins.QTM Reader 0x03f2d570 FileOpenData(KGDictInt*) + 88
    15 …alCutPro.Plugins.QTM Reader 0x03f449e8 PluginMainEntry(long, long, KGDictInt*, void*) + 2364
    16 com.apple.FinalCutPro 0x0024edc4 pKGOpenFile(KGFileRec*, unsigned long) + 212
    17 …alCutPro.Plugins.QTM Reader 0x03f2fbf0 FileGetInfo(KGDictInt*) + 232
    18 …alCutPro.Plugins.QTM Reader 0x03f44a18 PluginMainEntry(long, long, KGDictInt*, void*) + 2412
    19 com.apple.FinalCutPro 0x00250ae4 GetInfoFromReader(KGFileRec*, KGDictInt*, char*) + 452
    20 com.apple.FinalCutPro 0x00251e8c pKGFileAddOrCheckImport(KGFileSpec*, char*, KGDictInt*, KGFileRec**, KGFileRec**) + 776
    21 com.apple.FinalCutPro 0x00251960 pKGFileAdd(KGFileSpec*, char*, KGDictInt*, KGFileRec**) + 48
    22 …CutPro.Plugins.Relink Media 0x03fae91c MakeFileEntryOnline(KGLinkInfoRec*, KGFileSpec*, unsigned char*) + 340
    23 …CutPro.Plugins.Relink Media 0x03fb4d60 FindMissingFiles(KGDictInt*, unsigned char, unsigned char) + 4432
    24 …CutPro.Plugins.Relink Media 0x03fb54cc PluginMainEntry(long, long, KGDictInt*, void*) + 780
    25 com.apple.FinalCutPro 0x001df5b8 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 360
    26 com.apple.FinalCutPro 0x001df78c HandleCommand(long, unsigned char, unsigned char, unsigned char) + 256
    27 com.apple.FinalCutPro 0x001e2aac HandleMouseDown(EventRecord*) + 624
    28 com.apple.FinalCutPro 0x001e5d84 Process1MacEvent(KGDictInt*) + 2520
    29 com.apple.FinalCutPro 0x001e625c KGMainEvent + 104
    30 com.apple.FinalCutPro 0x003de4b4 main + 832
    31 com.apple.FinalCutPro 0x0000430c _start + 392
    32 com.apple.FinalCutPro 0x00004180 start + 48
    Thread 1:
    0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
    1 libSystem.B.dylib 0x9000b29c mach_msg + 60
    2 com.apple.CoreFoundation 0x907de9b8 __CFRunLoopRun + 832
    3 com.apple.CoreFoundation 0x907de2bc CFRunLoopRunSpecific + 268
    4 com.apple.CoreFoundation 0x907ed71c CFRunLoopRun + 52
    5 com.apple.DVCPROHDMuxer 0x06e1c2bc AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 396
    6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 2:
    4 com.apple.audio.CoreAudio 0x91459524 HALRunLoop::OwnThread(void*) + 264
    5 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
    Thread 3:
    0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
    1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
    2 …ple.CoreServices.CarbonCore 0x90bf93f4 TSWaitOnSemaphoreCommon + 176
    3 …ickTimeComponents.component 0x99e16174 ReadSchedulerThreadEntryPoint + 5316
    4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 4:
    0 libSystem.B.dylib 0x9002f08c kevent + 12
    1 com.apple.DesktopServices 0x92af8e50 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
    2 …ple.CoreServices.CarbonCore 0x90bc6794 PrivateMPEntryPoint + 76
    3 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 5:
    0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8
    1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480
    2 …ple.CoreServices.CarbonCore 0x90bc6984 MPWaitOnQueue + 224
    3 com.apple.DesktopServices 0x92af94cc TNodeSyncTask::SyncTaskProc(void*) + 116
    4 …ple.CoreServices.CarbonCore 0x90bc6794 PrivateMPEntryPoint + 76
    5 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
    Thread 6:
    3 …ple.CoreServices.CarbonCore 0x90c03e9c AIOFileThread(void*) + 520
    Thread 0 crashed with PPC Thread State 64:
    srr0: 0x0000000090bb5ab8 srr1: 0x000000000200f030 vrsave: 0x0000000000000000
    cr: 0x24242222 xer: 0x0000000000000004 lr: 0x0000000004d54cf4 ctr: 0x0000000090bb5aa8
    r0: 0x0000000004d54cf4 r1: 0x00000000bfffd9d0 r2: 0x0000000000000006 r3: 0x0000000000000000
    r4: 0x00000000bfffdac0 r5: 0x0000000000000018 r6: 0x0000000074653f2e r7: 0x0000000069707200
    r8: 0x00000000746c6573 r9: 0x0000000000000000 r10: 0x00000000686f70ff r11: 0x0000000004d5d6dc
    r12: 0x0000000090bb5aa8 r13: 0x00000000fffff800 r14: 0x00000000bfffde20 r15: 0x00000000bfffde1c
    r16: 0x0000000000000000 r17: 0x00000000bfffe78c r18: 0x00000000bfffde2c r19: 0x00000000054bd884
    r20: 0x0000000000000000 r21: 0x0000000000000000 r22: 0x00000000616c6973 r23: 0x0000000000000000
    r24: 0x0000000000000000 r25: 0x00000000054bdd08 r26: 0x0000000000000000 r27: 0x0000000000000000
    r28: 0x000000000f49c980 r29: 0x00000000bfffddb4 r30: 0x0000000000000000 r31: 0x0000000090bdec24
    Binary Images Description:
    0x1000 – 0x434fff com.apple.FinalCutPro 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Final Cut Pro
    0x12b5000 – 0x12b9fff com.apple.FinalCutPro.Plugins.AudioGroupsExport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x12bd000 – 0x12c2fff com.apple.FinalCutPro.Plugins.Cache Manager 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x12d4000 – 0x12e3fff com.apple.FinalCutPro.Plugins.AudioMixer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x12e8000 – 0x12ebfff com.apple.FinalCutPro.Plugins.CTHelper 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0x12ee000 – 0x12f5fff com.apple.FinalCutPro.Plugins.Effect Builder 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0x12f8000 – 0x12fcfff com.apple.FinalCutPro.Plugins.LayerFileReader 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0x151d000 – 0x154afff com.apple.FinalCutPro.Plugins.AfterEffects 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x1557000 – 0x15e2fff com.apple.FinalCutPro.Plugins.Browser 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0x15fb000 – 0x1601fff com.apple.FinalCutPro.Plugins.MolokiniSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0x16a5000 – 0x16b7fff com.apple.FinalCutPro.CinemaTools 2.2 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0x16c0000 – 0x16d9fff com.apple.FinalCutPro.Plugins.EditTape 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0x16df000 – 0x1724fff com.apple.FinalCutPro.Plugins.EDL Export 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0x1735000 – 0x1742fff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0x1751000 – 0x177dfff com.apple.FinalCutPro.Plugins.FCS Engine 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0x178b000 – 0x179bfff com.apple.FinalCutPro.Plugins.FilterCustomEd 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0x179f000 – 0x17b2fff com.apple.FinalCutPro.Plugins.FilterViewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0x17b6000 – 0x17cdfff com.apple.FinalCutPro.Plugins.Flash 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0x17d8000 – 0x17e4fff com.apple.FinalCutPro.Plugins.GenViewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0x17e8000 – 0x17f7fff com.apple.FinalCutPro.Plugins.Movie Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x17fc000 – 0x17fdfff com.apple.FinalCutPro.Plugins.Text Window 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0x3c84000 – 0x3caefff com.apple.FinalCutPro.Plugins.G4 Accelerator 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/G4 Accelerator.bundle/Contents/MacOS/G4 Accelerator
    0x3cb5000 – 0x3ccbfff MolokiniTranslation /Final Cut Pro HD 4.5.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0x3ce6000 – 0x3ce9fff com.apple.FinalCutPro.Plugins.NuggetExport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0x3cec000 – 0x3cf3fff com.apple.FinalCutPro.Plugins.Perf Analyzer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0x3e05000 – 0x3e4afff com.apple.FinalCutPro.Plugins.Media Manager 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0x3e56000 – 0x3e6dfff com.apple.FinalCutPro.Plugins.Motion Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0x3e72000 – 0x3e84fff com.apple.FinalCutPro.Plugins.Movie Analyzer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0x3e90000 – 0x3ef7fff com.apple.FinalCutPro.Plugins.OMF Audio Export 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0x3f0f000 – 0x3f18fff com.apple.FinalCutPro.Plugins.Pulldown Support 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0x3f1d000 – 0x3f49fff com.apple.FinalCutPro.Plugins.QTM Reader 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0x3f56000 – 0x3f8bfff com.apple.FinalCutPro.Plugins.QTRtEffects 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QTRtEffects.bundle/Contents/MacOS/QTRtEffects
    0x3f9f000 – 0x3fa7fff com.apple.FinalCutPro.Plugins.QuickView 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0x3faa000 – 0x3fb5fff com.apple.FinalCutPro.Plugins.Relink Media 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0x3fba000 – 0x402bfff com.apple.FinalCutPro.Plugins.Timeline Editor 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0x403d000 – 0x4043fff com.apple.FinalCutPro.Plugins.Transcoder 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0x4048000 – 0x405afff com.apple.FinalCutPro.Plugins.Transition Viewer 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0x405f000 – 0x4076fff com.apple.FinalCutPro.Plugins.Trimming 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0x407b000 – 0x4082fff com.apple.FinalCutPro.Plugins.VDUSupport 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0x4086000 – 0x4097fff com.apple.FinalCutPro.Plugins.VideoLog 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0x409c000 – 0x40b6fff com.apple.FinalCutPro.Plugins.VoiceOver 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0x40be000 – 0x40cffff com.apple.FinalCutPro.Plugins.Waveform Monitor 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/Waveform Monitor.bundle/Contents/MacOS/Waveform Monitor
    0x40d4000 – 0x4170fff com.apple.FinalCutPro.Plugins.XML Support 4.5 /Final Cut Pro HD 4.5.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0x4474000 – 0x4484fff com.apple.FCP Uncompressed 422.component 1.0.5 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x44fc000 – 0x44fdfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
    0x4d53000 – 0x4d5cfff com.apple.LiveType.component 1.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x4d68000 – 0x4dccfff com.DivXInc.DivXDecoder 6.6.0 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x4dda000 – 0x4e53fff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
    0x503f000 – 0x50b6fff com.apple.DVCPROHDCodec 1.0 (112) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x50cc000 – 0x5145fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x51e6000 – 0x51fffff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
    0x5223000 – 0x522afff com.unsanity.smartcrashreports Smart Crash Reports version 1.2.1 (1.2.1) /Users/hannahdee/Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
    0x529c000 – 0x52a0fff com.apple.iokit.IOQTComponents 1.4 /System/Library/Components/IOQTComponents.component/Contents/MacOS/IOQTComponents
    0x538f000 – 0x53aefff com.apple.fcp.DVOutputUnit 1.2 /Final Cut Pro HD 4.5.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0x5493000 – 0x54aefff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x5605000 – 0x5714fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x5743000 – 0x599afff com.apple.ATIRadeon8500GLDriver 1.4.18 (4.1.8) /System/Library/Extensions/ATIRadeon8500GLDriver.bundle/Contents/MacOS/ATIRadeon8500GLDriver
    0x6c05000 – 0x6c8efff com.apple.DVCPROHDAudio 1.0 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x6e05000 – 0x6e97fff com.apple.DVCPROHDMuxer 1.0 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x6ec6000 – 0x6f23fff com.apple.DVCPROHDVideoOutput 1.0 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x6f36000 – 0x6f6ffff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x6f75000 – 0x6f7cfff com.apple.DesktopVideoOut 1.2.1 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x6f80000 – 0x6f8afff com.apple.IOFWDVComponents 1.7.9 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x7100000 – 0x71c2fff com.apple.audio.units.Components 1.3.4 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0xa572000 – 0xa5c13c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
    0xa5c13d0 – 0xa5d96bd Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia
    0xa6a4000 – 0xa8ddfff net.telestream.wmv.import 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0xa913000 – 0xaac7fff net.telestream.wmv.advanced 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0xd56e760 – 0xd56e812 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
    0xd56ea00 – 0xd56eab5 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue
    0xd56ecd0 – 0xd56ed73 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime
    0xd56ede0 – 0xd56ee57 CFMPriv_System PEF binary: CFMPriv_System
    0xd56f0d0 – 0xd56f1a0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
    0xd56f210 – 0xd56f2e3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
    0xd56f3b0 – 0xd56f46b CFMPriv_Help PEF binary: CFMPriv_Help
    0xd56f470 – 0xd56f53a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
    0xd56f5b0 – 0xd56f686 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
    0xd56f6f0 – 0xd56f7c3 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
    0xd56f840 – 0xd56f925 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
    0xd56f990 – 0xd56fa66 CFMPriv_OpenScriptingMacBLib PEF binary: CFMPriv_OpenScriptingMacBLib
    0xd56fb30 – 0xd56fbee CFMPriv_Print PEF binary: CFMPriv_Print
    0xd56fc00 – 0xd56fccd CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
    0xd56fd40 – 0xd56fe22 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
    0xd56fe90 – 0xd56ff63 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
    0xd56ffd0 – 0xd5700a3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
    0xd570170 – 0xd570232 CFMPriv_AE PEF binary: CFMPriv_AE
    0xd570240 – 0xd570305 CFMPriv_ATS PEF binary: CFMPriv_ATS
    0xd570370 – 0xd570447 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
    0xd5704c0 – 0xd5705a3 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
    0xd570610 – 0xd5706ea CFMPriv_HIServices PEF binary: CFMPriv_HIServices
    0xd570750 – 0xd570830 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
    0xd5708b0 – 0xd570996 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
    0xd570a60 – 0xd570b37 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
    0xd570b40 – 0xd570c02 CFMPriv_QD PEF binary: CFMPriv_QD
    0xd570cf0 – 0xd570dd9 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
    0xd605000 – 0xdaeb393 PEF binary:
    0xe9cf000 – 0xe9e5fff libJapaneseConverter.dylib /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0x10000000 – 0x10048fff com.apple.fcp.AudioMixEngine 1.5.6 /Final Cut Pro HD 4.5.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x41410000 – 0x414affff com.apple.QuickTimeImporters.component 7.2 /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
    0x419b0000 – 0x419effff com.apple.QuickTimeFireWireDV.component 7.2 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0x70090000 – 0x700e6fff com.apple.LiveType.framework 1.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0x70241000 – 0x70299fff com.apple.swamp.ServiceControl 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x72e36000 – 0x72f5bfff com.apple.stomp.transcoding 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x80ca7000 – 0x80cfefff com.apple.swamp.SwampService 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x81a84000 – 0x81adafff com.apple.swamp.RequestProcessing 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x835a6000 – 0x83612fff com.apple.swamp.SwampCore 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x83663000 – 0x836bafff com.apple.swamp.SwampExecutor 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x83b31000 – 0x83b42fff com.apple.stomp.MediaServerAPI 1.2.1 /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0x83b6f000 – 0x83b82fff com.apple.swamp.ClusterManager 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x83d97000 – 0x83deffff com.apple.swamp.SwampUtil 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x83ec0000 – 0x83f14fff com.apple.stomp.FilterUI 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x85041000 – 0x8504afff com.apple.stomp.StompUtil 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x85065000 – 0x850e3fff com.apple.stomp.StompTypes 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x86ed3000 – 0x86f91fff com.apple.AECore 1.2.1 /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x8831d000 – 0x883aefff com.apple.swamp.do 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x8a200000 – 0x8a229fff com.apple.swamp.SwampTypes 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x8a599000 – 0x8a5f5fff com.apple.swamp.Status 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x8a7fa000 – 0x8a85efff com.apple.swamp.ContentControl 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x8b545000 – 0x8b5a8fff com.apple.swamp.SwampUI 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x8b709000 – 0x8b7d1fff com.apple.swamp. JobControl 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x8ba31000 – 0x8ba39fff com.apple.Helium 1.0.1 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0x8c31e000 – 0x8c331fff com.apple.AERegistration 1.2 (41) /Final Cut Pro HD 4.5.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0x8c770000 – 0x8c7e3fff com.apple.stomp.StompUI 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x8cae4000 – 0x8cb10fff com.apple.stomp.ImageProcessing 1.2.1 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x8cb52000 – 0x8cb5afff com.apple.AEProfiling 1.2 (8) /Final Cut Pro HD 4.5.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0x8cba7000 – 0x8cba7fff com.apple.swamp.swamp 1.2.1 /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0x8cbaa000 – 0x8cbaafff com.apple.stomp.stomp 1.2.1 /Library/Frameworks/Compressor.framework/Compressor
    0x8f4f0000 – 0x8f4f5fff com.apple.CoreMediaAuthoringPrivate 1.2 /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate
    0x8f840000 – 0x8f86efff com.apple.CoreMediaPrivate 1.4 /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
    0x8fe00000 – 0x8fe52fff dyld 46.16 /usr/lib/dyld
    0x90000000 – 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
    0x90214000 – 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
    0x9021b000 – 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90293000 – 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x90373000 – 0x9072efff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x907bb000 – 0x90895fff com.apple.CoreFoundation 6.4.9 (368.31) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x908de000 – 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x908e0000 – 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
    0x90a3c000 – 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
    0x90aea000 – 0x90b5cfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90b72000 – 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
    0x90b8b000 – 0x90e62fff com.apple.CoreServices.CarbonCore 681.17 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90ec8000 – 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x90f92000 – 0x90fd4fff com.apple.CFNetwork 4.0 (129.22) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x90fe9000 – 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
    0x91011000 – 0x91092fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x910d8000 – 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x91112000 – 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
    0x91123000 – 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x913dd000 – 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x913ed000 – 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
    0x913f9000 – 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x91434000 – 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
    0x91444000 – 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x914fc000 – 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x914fe000 – 0x91536fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x91551000 – 0x91623fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x91676000 – 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x9174e000 – 0x91805fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x91842000 – 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x918cf000 – 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x91904000 – 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
    0x9193c000 – 0x9197efff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x9199a000 – 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x919bc000 – 0x91a02fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x91a19000 – 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
    0x91b2e000 – 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
    0x91b48000 – 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91b6c000 – 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x91c72000 – 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x91c78000 – 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
    0x91ce7000 – 0x91d24fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91d2b000 – 0x91d45fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91d4a000 – 0x91d4dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91d4f000 – 0x91e2dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x91e4d000 – 0x91e4dfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91e4f000 – 0x91f34fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91f3c000 – 0x91f5bfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91fc7000 – 0x92035fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x92040000 – 0x920d5fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x920ef000 – 0x92677fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x926aa000 – 0x929d5fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x92a05000 – 0x92af3fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92af6000 – 0x92b7efff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x92bbf000 – 0x92deafff com.apple.Foundation 6.4.9 (567.36) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92f17000 – 0x92f35fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92f40000 – 0x92f9afff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92fb8000 – 0x92fb8fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92fba000 – 0x92fcefff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92fe6000 – 0x92ff6fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x93002000 – 0x93017fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x93029000 – 0x930b0fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x930c4000 – 0x930cffff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x930d9000 – 0x93106fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x93120000 – 0x9312ffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x9313b000 – 0x931a1fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x931d2000 – 0x93221fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x9324f000 – 0x9326cfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x9327e000 – 0x9328bfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x93294000 – 0x935a2fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x936f2000 – 0x936fefff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x93703000 – 0x93723fff com.apple.DirectoryService.Framework 3.3 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93797000 – 0x937b7fff libmx.A.dylib /usr/lib/libmx.A.dylib
    0x937bd000 – 0x937bdfff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x937bf000 – 0x93df2fff com.apple.AppKit 6.4.9 (824.44) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9417f000 – 0x941f1fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x9422a000 – 0x942effff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x94342000 – 0x94342fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x94344000 – 0x94504fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9454e000 – 0x9458bfff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x94593000 – 0x945e3fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x945ec000 – 0x94606fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x947b4000 – 0x947c3fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x947cb000 – 0x947d8fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9481e000 – 0x94837fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x9483e000 – 0x94b68fff com.apple.QuickTime 7.4.0 (92) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94c4e000 – 0x94cbffff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x94e34000 – 0x94f64fff com.apple.AddressBook.framework 4.0.6 (490) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x94ff7000 – 0x95006fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x9500e000 – 0x9503bfff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x95042000 – 0x95052fff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
    0x95056000 – 0x95085fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
    0x95095000 – 0x950b2fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
    0x97aea000 – 0x97b09fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x98220000 – 0x982e1fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x9830c000 – 0x9830dfff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
    0x9830f000 – 0x9831cfff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x99dfe000 – 0x9a9c4fff com.apple.QuickTimeComponents.component 7.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x9ac1d000 – 0x9ac21fff com.apple.QuickTimeH264.component 7.2 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x9ac23000 – 0x9ad32fff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x9aea9000 – 0x9af76fff com.apple.QuickTimeMPEG4.component 7.2 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9b944000 – 0x9b945fff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9b952000 – 0x9b996fff com.apple.viceroy.codec 31.0 (31) /System/Library/Components/VCH263Codec.component/VCH263Codec
    Model: PowerMac6,4, BootROM 4.9.2f1, 1 processors, PowerPC G4 (1.5), 1.25 GHz, 768 MB
    Graphics: ATI Radeon 9200, ATY,RV280, AGP, 32 MB
    Memory Module: DIMM0/J2, 256 MB, DDR SDRAM, PC2700U-25330
    Memory Module: DIMM1/J1, 512 MB, DDR SDRAM, PC2700U-25330
    Network Service: Internal Modem, PPP (PPPSerial), modem
    Network Service: Built-in Ethernet, Ethernet, en0
    Parallel ATA Device: PIONEER DVD-RW DVR-107D
    Parallel ATA Device: Maxtor 6Y080L0, 76.33 GB
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: Apple Optical USB Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    FireWire Device: LaCie FW800 Big Disk drive LUN 0, LaCie Group SA, Up to 400 Mb/sec
    FireWire Device: LaCie d2 Extreme LUN 0, LaCie Group SA, Up to 400 Mb/sec
    May Bolton replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
