Activity Forums Avid Media Composer Reconnect using AMA
  • Reconnect using AMA
    Posted by Chris Mcelroy on September 16, 2013 at 7:30 pm
    I inherited a a project from a previous editor on Media Composer 6.5
    He was in the habit of editing using AMA. I am unable to connect to the media, even though it is on a local drive. Any advice?
    thanks
    Sean Smith replied 12 years, 12 months ago 3 Members · 2 Replies
  • Khoren Mirzakhanian
    September 18, 2013 at 6:48 pm
    load the ama clips in a bin, either by “link to ama files” or “load ama volume”
    then select your sequence and relink. should do the trick. also check to see if those clips that are offline, have tape names.
  • Sean Smith
    October 1, 2013 at 1:11 am
    I think you might have to have the clips in the AMA bin selected when you relink too.
