Activity Forums DaVinci Resolve Reconnect Prores to MXF camera data
  • Reconnect Prores to MXF camera data
    Posted by John Treffer on April 21, 2016 at 8:37 pm
    I work with several editors who still prefer to edit in FCP7.
    I shoot with an FS7, export all footage with LUT applied as individual prores movs.
    Get an XML back from FCP7 that I can import in Resolve.
    My question: Is there a way to reconnect this edit to the original MXF camera files?
    John Treffer replied 10 years, 4 months ago 2 Members · 2 Replies
  • Joseph Owens
    April 22, 2016 at 2:38 am
    [John Treffer]
    Yes, there is. A couple of ways in case one of them doesn’t function as expected.
    User Manual Reference: Read the section on Importing Projects Relinking Media.
    Specifically, “Automatically Import” and “Link to source camera files” is the normal path if the naming conventions have been preserved through the editing process. It might be a little more challenging if this workflow has not been adhered to.
    If the filename, TC and/or Reel numbers don’t synchronize, then you may be into a force-offline, import media, hope for the best / force conform scenario.
    More Info is contained in the sections titled “Conforming XML and AAF Files.”
    It should work more simply than it sounds, but knowing how it works will enable you to troubleshoot the links if it doesn’t.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • John Treffer
    April 22, 2016 at 9:22 am
    Thanks! I will look into it.
    Filenaming is coherent, but extension is different, that is where it went wrong last time. I also heard they worked on relinking in the 12.5 update, so that might help as well.
