Activity Forums Apple Final Cut Pro Legacy reconnect media not working
  • reconnect media not working
    Posted by Roli Rivelino on August 4, 2011 at 12:10 pm
    I have a project which I moved onto another drive to create space, however when I try and reconnect the media is greyed out. I tried to reconnect to the media’s new location and I’ve moved it backed to its new location, all to no avail.
    Any help or suggestions would be greatly appreciated.
    Many thanks
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 15 years, 1 month ago 2 Members · 4 Replies
  • Jerry Hofmann
    August 4, 2011 at 4:31 pm
    Can you import the media? If you can, does it have the same names as the clip names you’re attempting to connect to?
    Jerry
  • Roli Rivelino
    August 4, 2011 at 9:27 pm
    Yes I tried re-importing the tapes (it’s a dv project) and that still didn’t work.
    As far as naming’s concerned I’ve given the various sub clips different names, but don’t think I changed the source clips.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Jerry Hofmann
    August 5, 2011 at 12:49 pm
    You can’t just choose file/import/files, and select those files you’ve moved? If not, they might be corrupt and you need to recapture from your tapes.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Roli Rivelino
    August 5, 2011 at 4:43 pm
    OK, actually reimport them into the bins you mean? I’ll try that and see if it works.
    many thanks
    System
    8Gb RAM
    Equipment
    Firestore FS-100
