Activity Forums Apple Final Cut Pro Legacy reconnect media failed,,,why?
  • reconnect media failed,,,why?
    Posted by Bob Flood on May 5, 2006 at 4:54 pm
    Hi
    After recapturing a bunch of clips, I get the error message “unable to reconnect to file xxxxx, try recapturing” im paraphrasing here, but does anyone knows why this comes up? bad video? bad tc? bad harddrive? bad mojo?
    thanx in advance
    bee eph
    Bob Flood
    Greer & Associates, Inc.
    Ben Holmes replied 20 years, 4 months ago 2 Members · 3 Replies
  • Ben Holmes
    May 5, 2006 at 5:04 pm
    Have you recaptured using different settings? Frame-rate the same?
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    Producer/Director “The Supercar Run” now available for international distribution from http://www.electricsky.com
  • Bob Flood
    May 5, 2006 at 7:16 pm
    ben
    the clips were from and edl import capturing from beta sp 8 bit 525
    I also keep getting these prompts to rename a file name, and i have tried it both ways (new name AND Skip)
    thanx
    “I like video because its so fast!”
    Bob Flood
  • Ben Holmes
    May 5, 2006 at 7:33 pm
    Sorry Bob – not familiar with edl imports, although it seems likely that fcp can’t get enough ‘hooks’ to reconnect this data. It uses timecode, reel info and clip name; if these all match….
    I have found in the past that reconnecting individual clips or a small number can be easier than trying to get fcp to relink everything – sometimes a single clip, or a phantom media-manager clip (MM is a notorious glitcher in some versions of FCP) can cause a problem, where 99% are fine. Have you tried a random selection of single clips to see if ANY reconnect?
    Sorry to be of little help. The Cow will know.
    ben
