Activity Forums Apple Final Cut Pro Legacy Reconnect Media Failed!
  • Reconnect Media Failed!
    Posted by David Scott on February 13, 2007 at 11:57 am
    Hi
    Anyone know why when trying to recapture media to an old (FCP4.5) project it throws up the error message “reconnect media failed” and suggests recapturing, which of cause does not work! The clip has accually been captured and I can import it but it is corrupt. If I drag the clip from the timeline to the bin and capture from there it works but then needs reconnecting, and I only have 600 clips to do!
    All thoughts welcome!
    Cheers
    David Scott
    David Scott replied 19 years, 7 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    February 13, 2007 at 5:34 pm
    If you disconnect the clips in the sequence from the media files (easy to do, just trash the originals or move them to another folder) you can’t recapture? What happens? (“of course it doesn’t work” doesn’t really explain what’s going on).
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Scott
    February 14, 2007 at 11:30 am
    Hi Jerry
    Sorry I was not very clear – I’ll start again!
    I cut a fast paced 10min piece a couple of years ago using FCP4.5HD, and have long since needed to ditch the media to free up drive space. I have been asked to do an update on the item using most of the old clips but inserting some new ones, so I need to recapture the old media.
    I have openned the old project in FCP 5.0.4 and tried to batch capture the media (BetaSP) from the time line – I did not want to capture from the browser as it contains hundreds of clips (now all offline) that I ultimately did not use in the cut. FCP seems to capture a clip then throws up an error message “Reconnect Media Failed”. The Quicktime movie is in the Capture Scratch, but is corrupt, and does not appear in the browser window.
    I found that if I copy the sequence into a new project, and then copy the clips to the browser and recapture from there, some of them will capture, but then require relinking to the clips in the timeline as they are still offline.
    I have a lot of clips to capture and this is slow.
    Do you know why it is not caputuring the clips correctly from an old project?
    Hope this makes more sense!
    Many thanks
    David
