Activity Forums Apple Final Cut Pro Legacy Recompressing HD for DV offline
  • Recompressing HD for DV offline
    Posted by Carl Anderson on July 20, 2006 at 3:41 pm
    I am having problems recompressing for offline.
    Starting with uncompressed 10 bit, 1920×1080, 23.98, captured with Kona3.
    I Recompress media using DV NTSC 48kHz-23.98.
    The new canvas is 16:9 but will only display a distorted (squeezed) picture.
    I have checked the Anamorphic box in Sequence Settings.
    Any thoughts?
    Mark Maness replied 20 years, 2 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    July 20, 2006 at 3:47 pm
    Does your monitor display 16X9? Have you switched it to 16X9?
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
  • Carl Anderson
    July 20, 2006 at 4:00 pm
    Are you referring to a NTSC display?
    I have a 23″ Apple Cinema Display.
    I hope to use it alone while off-lining.
  • Mark Maness
    July 20, 2006 at 7:03 pm
    not a good idea! you should always monitor your video using an NTSC monitor.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
