Activity Forums AJA Video Systems Recommended preservation quality SD capture card
  • Recommended preservation quality SD capture card
    Posted by Mark Curry on November 21, 2006 at 8:33 pm
    Hello,
    I’m wanting to migrate 3/4″, BetaSP, and DigiBeta sources to a “preservation” quality codec/file. Ideally, I would like 4:4:4, 10-bit, YUV. Of these 3 specs I think the most important is the compression. The Kona 3 looks good, but doesn’t do analog capture. The Kona LSe looks more suitable but appears not to be 4:4:4. Blackmagic doesn’t appear to have anything suitable. The Kona 3 with the Kona Io may be suitable, but frankly I don’t know. Recommendations? Suggestions?
    David Battistella replied 19 years, 10 months ago 4 Members · 14 Replies
  • 14 Replies
  • Bob Zelin
    November 21, 2006 at 10:47 pm
    The Kona 3 is used by everyone, including AVID for the Nitris for 4:4:4 input. 3/4″ will look like crap, no matter what you do with it. You take the SDI output of your Digi Beta, and go into the HD input of the Kona 3, and it will upconvert this signal to anything you want – but it will be in a 720p or 1080i format – it ain’t 4:4:4. For Beta, simply play the tapes out of your Digi Beta VTR, the same process – SDI upconverted to HD 10 bit.
    SO, how are you going to store this massive archive.
    Bob ZElin
  • Mark Curry
    November 21, 2006 at 11:07 pm
    Hi Bob,
    I’m not concerned with “improving” or upconverting any footage; I want to retain as faithfully as possible the information that is there. I want to minimize any errors, compression artifacts, or scaling to the transcoded footage. The intent is to transfer the content to a newer and more stable carrier while preserving the technical nature of the content, using the best available hardware to minimise the signal deterioration usually connected with the transfer of the content. Yes, I expect some of the footage to be quite poor (some are early 70’s, degraded 3/4″ tapes), but regardless I want that information! This is in short a digital preservation job.
    The Kona 3 looks to be a good choce for the DigiBeta material, but not for the analog material as this card is SDI only …
    I will be capturing to SATA Raids and storing each asset either in multiiple offline SATA drives or in an external SATA Raid.
    Mark
  • Bob Zelin
    November 22, 2006 at 12:04 am
    you can play back any Beta SP tape in any Digi Beta VTR, and it will convert it to SDI for you. If for some reason this is not acceptable, you can get the AJA HD10AVA, which will convert the analog component video to SDI, and embed the analog audio right into the SDI stream. The output of the AJA HD10AVA can be plugged directly into the SDI input of the Kona 3.
    As for analog composite, another excellent suggestion is the AJA I/O box. This box will convert the analog composite signal to SDI. It will also embed the analog audio into the SDI stream. This can be put directly into the Kona 3. If you choose to get the AJA I/O, then you DO NOT need to purchase the HD10AVA, as the I/O will do the same job of encoding the analog component Y R-Y B-Y signal to SDI (with embedded audio if you like) – you then take the SDI out of the AJA I/O, and go right into the Kona 3.
    Is this acceptable to you, or would you like other suggestions ?
    Bob Zelin
  • Arnie Schlissel
    November 22, 2006 at 1:37 am
    [Bob Zelin] “3/4″ will look like crap, no matter what you do with it.”
    Why Bob, are you suggesting that garbage in will get you garbage out? 😉
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • David Battistella
    November 22, 2006 at 12:55 pm
    Take a look at Bit Jazz Sheer Video codecs for archiving. I have been using them for years. Lossless, about a third the size of uncompressed. Very efficenet. Totaly QT compatible and fast as well.
    David
    Peace and Love 🙂
  • Mark Curry
    November 25, 2006 at 9:38 pm
    I’ve been researching SD (standard def) capture further and have learned that the SDI (Serial Digital Interface) 4:4:4 protocol is is an HD spec (called dual-link). In other words, a SD source to a Kona converter (HD10AVA, IO, etc) with Kona 3 card yields a 4:2:2 SD capture. That is why the Kona LSe is 4:2:2 – that is the best native sampling for SD SDI.
    However, if one captures the SD footage via the Kona 3 using dual-link SDI the card will upsample the footage to an HD 4:4:4 spec. However, I believe it would scale the footage (though maintaining the aspect ration) in the process. Yes? Is there an option to capture the SD without any scaling (i.e. small image say 640×480 within a 1080 frame)? Then I would crop from there (minding field issues) resulting in an acceptable 4:4:4 SD capture process and file. Is this at all possible? If not, scaling is unacceptable. Instead, I would research the possibility of a turnkey system which digitizes SD analog at 4:4:4 and then barring that will likely accept capturing at 4:2:2 via either the Kona 3 with a Kona converter or via the Kona LSe.
    p.s. thanks David for the BitJazz codec which I’m famiiar with. I’m still researching codecs suitable for a preservation project. I suspec I will opt for Animation as it is stable/mature (i.e. likely to be around longer than BitJazz)
  • Arnie Schlissel
    November 25, 2006 at 10:04 pm
    [chimpybits] “I’ve been researching SD (standard def) capture further and have learned that the SDI (Serial Digital Interface) 4:4:4 protocol is is an HD spec (called dual-link)”
    Dual link is only 1 of 3 different SDI standards, each described by SMPTE. There is also a specific SD standard. The Kona 3 can provide all 3 types of SDI in and out, and will also cross convert between them.
    Arnie
  • Mark Curry
    November 25, 2006 at 10:12 pm
    Yes that is right – dual link though is the only one that is 4:4:4 (as gathered from WIkipedia and discussion with Aja). Hence, there is no SD 4:4:4 available for any SDI card (i.e. all Kona cards).
  • David Battistella
    November 26, 2006 at 12:07 am
    FYI,
    As long as Quicktime is around Bitjazz will be around.
    If you want to store files that are four to six times larger. That’s fine too. PNG is alos a nice alternative to Annimation and Photo J-peg at 100% is also a 4:4:4 codec and holds up very well.
    The beauty of the Bitjaz archive it that if you drop it into a SHeer timeline you can use it right away. You will always have to render the annimation codec.
    So you then have the double storage issue of the annimation codec plus the Render files you need to generate to actually use it.
    PLease stay tuned for a very in depth article on the COW covering the use of these codecs in various workflows. ONe thing to understand Bitjazz and Animation (same quality)
    David
    Peace and Love 🙂
  • Mark Curry
    November 26, 2006 at 12:49 am
    Hi David,
    This codec discussion is a side topic from my posted thread. I’ve worked with all the codecs you mention and in short we will be giving this careful consideration. Yes, QuickTime includes all old codecs for future legacy purposes, but they do become obsolete as workflows/systems move away from some codecs (Video codec anyone?). BitHJazz is a very impressive codec yes (as described here https://codecs.onerivermedia.com/).
    My main concern presently is working how to capture 4:4:4 SD.
