Activity › Forums › DSLR Video › Recommended Lens for Canon T2i/550D
  • Recommended Lens for Canon T2i/550D
    Posted by Joey Sahakian on February 3, 2011 at 5:16 pm
    Hello all,
    I just wanted to see if anyone had any recommendations for a good quality lens for shooting video with a Canon T2i/550D. I have used the kit lens that came with it but I am in the market for a lens of higher quality.
    Malcolm Matusky replied 15 years, 6 months ago 7 Members · 14 Replies
  • 14 Replies
  • Sohrab Sandhu
    February 3, 2011 at 6:44 pm
    If only you would care to google this question, you will find tons of posts where this question has been answered umpteen times!
    2.66 GHz 8-core, ATI Radeon HD 4870,
    FCS 3, AJA Kona Lhi
    “The creative person wants to be a know-it-all. He wants to know about all kinds of things: ancient history, nineteenth-century mathematics, current manufacturing techniques, flower arranging, and hog futures. Because he never knows when these ideas might come together to form a new idea. It may happen six minutes later or six months, or six years down the road. But he has faith that it will happen.” — Carl Ally
  • Joey Sahakian
    February 3, 2011 at 7:10 pm
    Ok. Thank you very much for your condescending answer to my question, which has still not been answered. I like to get opinions from others on different forums and I have seen that those who post to this forum usually have more knowledge than just doing a Google search. Next time if you don’t have anything nice to say, please don’t say it at all. Oh, I saw that saying in a Google search.
  • Richard Cooper
    February 3, 2011 at 7:56 pm
    Hi Joey,
    The key here in “LENSES” not “Lens” You will need a collection of lenses to cover your bases… and here are a few basic considerations.
    If you want to work with zooms then you should make sure that it has a constant aperture throughout the entire range of the zoom. This adds considerable cost to the glass but that is the trade off for the right lenses.
    First get your self a good low light wide angle zoom. The Canon 17-35mm f2.8L is a great lens. It gives options for composing your shots between the 17mm and 35mm range.
    Next you need the middle range and for that the Canon 24-70mm f/2.8L will do nicely for those semi-wide shots through the portrait type blow the BG out of focus type shots.
    Depending on your needs and shooting style these two lenses could cover most of your bases and are a great pair of lenses to start with. If you need a longer focal length then the final lens I would suggest the Canon EF 70-200mm f/2.8 L This is a great piece of glass!! and you will pay for it! hehehe
    OK so if you want to work in lower light situations or just want to go for that “razor thin” DoF, going with low light (f1.2 f1.4 etc) primes may be another route for you… but then there are other considerations. You need enough lenses to cover all of your possible and useful focal lengths. These typically fall like this. I nice wide 17mm (you can even find 11mm in some brands) a 24mm, 35mm, 50mm, 85mm. Now these lenses should be the lowest light glass you can find and/or afford. a f1.2 or f1.4 / 50mm lens will blow your mind! And as with any high quality glass, the lower the light capability, the higher the price exponentially!
    This prime set will, again, cover most of your bases and if you need to go longer than this I would still recommended the 70-200mm f/2.8 L as you will get really expensive really fast trying to cover that focal range in low light primes.
    Hope this helps you sort the options out. As with any equipment purchase, there are many more options, this is just a basic rundown to get you moving in the right direction.
    Good Luck!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Joey Sahakian
    February 3, 2011 at 8:13 pm
    Richard,
    Thank you for the thorough response. Nice to see helpful people in this forum.
  • Sohrab Sandhu
    February 3, 2011 at 11:33 pm
    [Joey Sahakian] “Next time if you don’t have anything nice to say, please don’t say it at all. Oh, I saw that saying in a Google search.”
    Good luck finding help with this kind of attitude, atleast on this forum!
    FCS 3, AJA Kona Lhi
  • Noah Kadner
    February 4, 2011 at 7:07 am
    https://lmgtfy.com/?q=best+lens+for+canon+t2i
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
  • Pete Burger
    February 4, 2011 at 8:40 am
    [Joey Sahakian] “Nice to see helpful people in this forum.”
    Well, Joey, I personally don’t know any forum on the web with more helpful people who are kind enough to share their experince and knowledge. I learned a lot just by reading other peoples posts.
    No offense meant, but it’s not too hard to use the forum search, before asking a question, that may have been discussed more than once.
    Here’s what I found:
    https://forums.creativecow.net/readpost/280/3328
    https://forums.creativecow.net/readpost/280/2725
    https://forums.creativecow.net/readpost/280/2746
    https://forums.creativecow.net/readpost/280/2228
    https://forums.creativecow.net/readpost/280/2070
    https://forums.creativecow.net/readpost/280/1558
    https://forums.creativecow.net/readpost/280/734
    Any questions left open? Please feel free to ask.
  • Noah Kadner
    February 5, 2011 at 12:57 am
    Sad thing is you’ll never hear from that overly pleasant person again on this board. Drive by seagull. Flies in, craps all over the place and flies back out again..
    Noah
  • Joey Sahakian
    February 6, 2011 at 4:25 am
    Thank goodness for that. I’ve always found a lot of help searching these forums. Thanks for the help all.
  • Norman Willis
    February 10, 2011 at 3:02 am
    Thanks.
    I have a Canon 5DM2 body, an F2.8L 16-35mm zoom and an F4L 24-105mm zoom. Right now I am doing some talking-head stuff in front of a bookcase, and the vertical lines are bowed. I shoot at about +/- 50mm. If I get a good 50mm prime, will that remove the distortion?
    I am looking at the Canon F1.4L, $379.00. I really like the idea of pulling it out of a box, putting it on, and using all of the stock Canon features without another learning curve. But now you guys are filling my head with talk of inexpensive used Nikon primes on EBay, and adapters. How big a deal is it to figure out how to use those? And what tradeoffs am I making by saving the +/- $250-300.00?
    Norman Willis
    http://www.nazareneisrael.org
