Activity › Forums › DSLR Video › Recommended Lens for Canon T2i/550D
  • Norman Willis
    February 10, 2011 at 2:52 pm
    Sounds like I just need to go with the Canon….
    Norman Willis
    http://www.nazareneisrael.org
  • Pete Burger
    February 11, 2011 at 10:06 am
    [Norman Willis] “If I get a good 50mm prime, will that remove the distortion?”
    I think with a good prime you’d be allright. Got the 50II 1.8 myself and have only very slight distortions. With rented more high quality lenses, I didn’t notice any distortions at all, but must admit, I haven’t looked for them 😉
    You could try to remove them in post. In After Effects there’s the “optics compensation” filter that does a good job. Used it sucessfully on a couple of clips.
    HTH
    Edit:
    To add: Forgot to mention that we use the 7D and the T2i (550D), so distortions may be more problematic with the 5DMkII due to it’s full frame sensor… So even with a lens that shows no/very little distortions on the smaller sensors could cause stronger ones on the 5D. Best would be to check different lenses, before buying… But a hq 50mm prime should nevertheless be more clean than your wide-angle zoom… imho
  • Norman Willis
    February 27, 2011 at 7:22 am
    Hey Peter.
    Just to follow up, the lines on the 1.4 are very close to straight.
    It is close enough I don’t feel the need to ‘take anything out.’ I will probably just deal with the lines by creative framing, and/or perhaps the creative use of fake foliage in order to camouflage the relatively minor curves in my new prime. : ]
    Norman Willis
  • Malcolm Matusky
    March 15, 2011 at 3:30 am
    I bought the 7D, 1.6x crop sensor and have been using the canon 17~55 f2.8 IS and the Tokina 11~16 f2.8; has been a great combination for me, I went with the non L lens because I wanted the IS for hand holding and am happy with my decision. Next lens 70~200 f4.0 IS. I have a few old nikon fast primes, pain to use them as the meter does not function properly. For my work, they have not been necessary.
    Malcolm
    http://www.malcolmproductions.com
Page 2 of 2
