Activity Forums Tape-to-Digital Recommendations for the best VHS (and S-VHS) converter box.
  • Recommendations for the best VHS (and S-VHS) converter box.
    Posted by Tad Newberry on October 10, 2024 at 5:18 am
    I have the VidBox but i notice a slight “flicker” (going from dark to light and back, just a little but continually). I’ve contacted the manufacturer and they say to reinstall the software, try different USB and RCA cables, even a different VHS deck, but the issue remains, so i’m guessing it’s the box. I found the ClearClick on Amazon and figure i’ll try it. Does this issue sound familiar to any of you? Did you find a solution?
    Marc Franklin replied 1 year, 8 months ago 2 Members · 6 Replies
  • Tad Newberry
    November 2, 2024 at 6:16 pm
    i just got the Digit Now Video Capture thing, and it’s squirrelly. The directions are poorly written, though i was able to capture directly in QuickTime, but it defaults to 16×9 (not good for VHS), and there’s some magenta discoloration on the top third of the screen.
    i might be returning this, unless i can figure out how to at least get rid of that discoloration. i was able to see the video on an OSB screen…and it didn’t have the discoloration, but i couldn’t choose the digit now card as a source, but it did show up on screen…so i maybe i just need to do it that way? do any of you have advice for another option? this seems like it should be easier.
  • Marc Franklin
    December 17, 2024 at 8:22 pm
    What deck are you using? Are you using a TBC? What quality are you looking for?
  • Tad Newberry
    December 20, 2024 at 6:22 am
    The deck is a JVC Super VHS ET, no TBC, and highest quality via the S-video cable.
  • Marc Franklin
    December 20, 2024 at 6:53 pm
    Find a TBC. The difference is night and day. Most digitizers won’t work properly without a TBC before it. If you can’t find a stand alone TBC, depending where you are you may be able to find a cheap Betacam SP recorder that will allow you to pass the video signal through its built in TBC. I have done this before with Betacam SP recorders and Panasonic AG-7750 pro S-VHS decks.
  • Tad Newberry
    December 21, 2024 at 9:56 pm
    Thanks for the tip. I just might have one tucked away in the garage somewhere. But now whether i still have BNC to RCA converters is another story. 😉
  • Marc Franklin
    December 22, 2024 at 2:07 am
    Amazon has them.
