Activity › Forums › Adobe Premiere Pro › recommendations
  • recommendations
    Posted by George Lucasade on January 16, 2007 at 5:31 pm
    I have Adobe premiere pro 1.5 which doesn`t function properly on my computer.I also have windows movie maker which is fine but not of the standard i need.
    Any recommendations on software somwhere between the 2 would be apprieciated.
    Terry
    Blast1 replied 19 years, 8 months ago 5 Members · 20 Replies
  • 20 Replies
  • Perry Cheng
    January 16, 2007 at 6:10 pm
    George,
    1st of all, what’s wrong w/ your PPro? Why not try to fix that since you already have it? 2nd what are you looking for to accomplish? Premiere Element might be what you need.
    Perry
  • George Lucasade
    January 16, 2007 at 6:18 pm
    Hi Perry.
    Thanks for getting back to me.
    I tried with the help of Mike Velde and others to fix the problem butwith no success.
    There is a large thread pertaining to the problem i have under this forum heading.
    Thanks for the information Perry.
    Terry
  • Mike Velte
    January 16, 2007 at 7:22 pm
    Try a demo of ScenalyzerLive to capture with. I have used it for years.
    http://www.scenalyzer.com
    https://www.video2stream.com
  • George Lucasade
    January 16, 2007 at 8:31 pm
    Thanks again Mike.
    I have just downloaded the demo which has captured fine.
    Is it possible to download music to this software to use over the top of the visuals.Also to narrate.
    Haveing viewed your profile Mike i see you are a videographer as well.
    I am now starting out with a canon XL1s with no prior experience.I will be going to a workshop to learn the basics at the end of the month.
    Have you any advice about earning a living as a videographer?
    Like you i am fed up with doing somthing i don`t enjoy and feel videography is the step to a happier future.
    You have as always been very helpful.
    Thanks again.
    Terry
  • Mike Velte
    January 16, 2007 at 9:18 pm
    Scenalyzer is just capture software…edit the files in Premiere.
    Music from where?
    [George Lucasade] “Have you any advice about earning a living as a videographer?”
    DO NOT quit your day job!! The problem with earning a living at any job is the “enjoyability factor” as it effects supply. Videography is high and therefor supply is high and wages are low.
    Waste management on the other hand is low and folks get paid darn good money for cleaning sewers.
    Of course using skill and talent and experience one can make good living in this biz, but the apprenticeship is long.
  • George Lucasade
    January 16, 2007 at 9:33 pm
    [mike velte] “Scenalyzer is just capture software…edit the files in Premiere.”
    Unfortunatly my Premiere Pro doesn`t work on my computer.
    When i`ve captured with MovieMaker it allows me to import music from my computer to use as background as well as or instead of dialogue.
  • Aanarav Sareen
    January 16, 2007 at 10:46 pm
    [George Lucasade] “Unfortunatly my Premiere Pro doesn`t work on my computer.”
    Hello,
    Can you specify what the problem is?
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Blast1
    January 16, 2007 at 11:04 pm
    [George Lucasade] “Unfortunatly my Premiere Pro doesn`t work on my computer”
    In what way outside of the capture problems you’re having? I’ve also noticed that you have not listed the specs of your system and how you are setting up your project, connection to your system and workflow up till you are having problems, this information is crucial to troubleshooting problems.
  • George Lucasade
    January 17, 2007 at 10:50 am
    Hi Aanarav.
    Thanks for asking.
    Everything is mentioned in the post January 13th.
    Mike Velde was very helpful but i was ubablr to get the problem sorted.
  • George Lucasade
    January 17, 2007 at 10:59 am
    Hi Blast 1.
    I believe you are right when you ask about system requirements,i havn`t enough of what i need to make the software perform properly.
    Premiere Pro 1.5 loads but i am unable to capture any footage from the tape.
    See post Jan 13th.
