Activity › Forums › Apple Final Cut Pro Legacy › Recombining m2v and .aiff into a single QT file
  • Recombining m2v and .aiff into a single QT file
    Posted by Les Kaye on October 15, 2007 at 2:20 am
    I’ve got separate video and audio files in the above formats that were created for burning in DVD Studio Pro. I also want to take this files and combine them into a single QT file. When I bring the files into FCP 5, playback starts out fine, but invariably starts going out of sync. I can’t seem to bring the files into DVDSP either for recombining. The video is MJPG B 29.97, and audio is 16bit 48khz.
    Suggesions? Thanks in advance.
    -Les Kaye
    Paul Provost replied 18 years, 11 months ago 4 Members · 5 Replies
  • David Roth weiss
    October 15, 2007 at 3:01 am
    Hey Les,
    You’ll have to convert the m2v to an editable QT format using MPEG Streamclip, then put that and the aiff on the timeline. I think you’ll find that they play in sync at that point.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Rafael Amador
    October 15, 2007 at 5:41 am
    Hi Les,
    If you got a MJPG B, you haven’t got a .m2v. “m2v” is an MPG2, but MJPG B is just a video codec (one of the many QT supported codecs).
    To put together the video and the audio is very easy with QT player. Do this with copies of the two files:
    – Open your movie with QT.
    – Open your .aiff with QT.
    – Select your .aiff and click Com-A (select all) and them, Com-C (Copy).
    – Click your movie and Option-Comm-V (Add to movie).
    Now you got the .aiff embed in the same file with the video. Play it and if is OK save it.
    Should work fine like that.
    You will get a MJPG B .mov with the original aiff audio. If you want to make a DVD, just bring that to DVDSTP or use Compressor.
    rafael
  • Les Kaye
    October 16, 2007 at 4:07 am
    I think you nailed it. The tracks are in sync throughout now. Many thanks
  • Les Kaye
    October 16, 2007 at 4:09 am
    Thanks Rafael, but it didn’t work. Both audio & video would still drift out of sync. David Weiss’ solution did the trick.
  • Paul Provost
    October 18, 2007 at 5:40 am
    build a ts folder with the files in dvdsp and then rip video with dvdxdv for best quality i find…
