Activity › Forums › Maxon Cinema 4D › Recolouring a material
  • Recolouring a material
    Posted by Stuart Samuels on October 13, 2013 at 2:20 pm
    Hi.
    I have a white fabric material that I wish to recolour to be red. I presumed this would be as simple as changing the colour sliders inside the material editor but this doesn’t seem to be the case (see the pics below). Is it possible to do this in C4D or will Ill I need to do it in Photoshop?
    Thanks.
    Stuart
    Stuart Samuels replied 12 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 13, 2013 at 3:40 pm
    You can do it in Cinema using the Filter shader, which contains a hue adjustment slider. Another option would be to use the colorizer shader which allows you to remap colors.
  • Stuart Samuels
    October 13, 2013 at 4:02 pm
    The colorizer worked perfectly! Thanks!
