Activity › Forums › Adobe After Effects › recognising mpeg codec
  • Realethan
    July 15, 2005 at 2:55 pm
    -Open your comp.
    -Ctrl-M to add it to the render queue.
    -Click on the text to the right (not the drop down spinner) of “Output Module” by default it will read “Lossless”
    -Change “Format” to “MPEG2”
    -The MPEG2 options dialog should pop-up immediately, click the “Format Options” button. Select “Video” and change it to the codec you’d like to use.
    -Hit OK and render.
