Activity › Forums › Adobe After Effects Expressions › Recoginize file type with expressions?
  • Recoginize file type with expressions?
    Posted by Mats Jacobsson on June 29, 2009 at 2:46 pm
    Hi!
    Is there an expression to recognize if the source file to a layer is vectorized or pixelated? It would also work if the expression just could detect the filetype of the layer.
    Thanks in advance!
    Dan Ebberts replied 17 years, 3 months ago 3 Members · 4 Replies
  • Dan Ebberts
    June 29, 2009 at 2:57 pm
    Only if you can deduce it from the name of the source file (probably by looking at the file extension). Here’s an example that should detect PSD files (not tested, so watch out for typos):
    mySplit = thisLayer.source.name.split[“.”]; // split source name at “.” characters
    myExtension = mySplit[mySplit.length – 1]; // get everything to the right of the last “.”
    if (myExtension.toLowerCase() == “psd”){
    // it’s a psd file
    }else{
    // it’s not a psd file
    Dan
  • Jean Pier biasiolo merchan
    June 29, 2009 at 6:17 pm
    Dan you're the best because even though the topic was not for me has served me very
    Un saludo
    Thanks you're the best, but it was not the issue for me has a lot of greetings
  • Mats Jacobsson
    June 30, 2009 at 7:02 am
    Wow, thanks a lot! Just what I needed.
    There was one small typo however, it should be (“.”) instead of [“.”] to work:
    mySplit = thisLayer.source.name.split(“.”); // split source name at “.” characters
    // it’s a psd file
    }else{
  • Dan Ebberts
    June 30, 2009 at 1:31 pm
    Good catch. I’m glad you figured it out and that it works for you.
    Dan
