Activity Forums Apple Final Cut Pro Legacy recaturing footage using time codes from previous footage
  • recaturing footage using time codes from previous footage
    Posted by Stellabeam on August 21, 2007 at 10:53 pm
    Hi everyone,
    Recaturing footage using digitised time codes from previously captured clips.
    Is this possible?
    I brought the clips in on the wrong setttings and the audio is 2 frames out of sync. Do I need to type in all the clip TCs again or can I batch capture using stored TCs.
    Thanks for your suggestions!!
  • Bouncing Account needs new email address
    August 22, 2007 at 2:57 am
    [stellabeam] “Recaturing footage using digitised time codes from previously captured clips.
    Is this possible?
    I brought the clips in on the wrong setttings and the audio is 2 frames out of sync. Do I need to type in all the clip TCs again or can I batch capture using stored TCs. “
    Highlight the “bad” clips in the Browser, then control-click and choose “Make Offline, remove from disk.”
    If there is a wrong setting in the Browser for these clips, change it at this point.
    Then, highlight the clips again and choose “Batch Capture.”
