Activity Forums Apple Final Cut Pro Legacy Recapture Footage With More Audio Channels
  • Recapture Footage With More Audio Channels
    Posted by Richard Lowe on July 17, 2009 at 11:46 pm
    Hi all–
    I’m coming onto a documentary that’s been in post for awhile. We’re trying to figure out what’s the best way to recapture footage with more audio channels. Here’s the situation:
    We originally captured some DVCPRO 150 footage in Final Cut with two audio channels, even though the footage was recorded with six. After some editing (a lot, actually) the editor wants to now recapture the same footage with all six discrete audio channels.
    My thought would be to unlink the current media, then doing a batch capture of the six-channel audio footage. Will this cause any major problems? Will the new footage relink properly to the two-channel footage? My gut says “no”; any help would be appreciated!
    Arnie Schlissel replied 17 years, 2 months ago 3 Members · 2 Replies
  • Andy Mees
    July 18, 2009 at 2:38 am
    Modify > Make Offline …
    Modify > Clip Settings …
    File > Batch Capture …
    should work, but try it on a couple of test clips / sequences first before you go the whole hog
  • Arnie Schlissel
    July 18, 2009 at 4:27 am
    [Richard Lowe] “Will the new footage relink properly to the two-channel footage?”
    Even if it does, those extra channels have not been cut into your timeline. If you want to add these extra channels into your edit, you’ll have to cut them in one at a time.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
