Here’s the deal. The DP shot on four cards in one day and each card change the first filename was MVI_0001.
When I first LT’d the footage I dragged all four cards for that day into the window and added a prefix to the filename on the way in like “DAY1”.
Sounds good, but when the footage comes in, the first card gets each file named correctly, but when FCP hits the second card and sees a new MVI_0001 it simply keeps ascending the numbers. By the end of the fourth card the file on the capture drive was MVI_0089, when in fact there was not a single file on any card with that name.
What’s worse is you have to remember exactly what order you brought the card folders into LT because if you bring in 1-4 the first time, and 4-1 the second time all the clips get mixed up.
I ended up using timecode (at least they recorded time of day!) so I could determine what clip went with the one in my sequences by timecode then I could re-transfer them, albeit with a new filename.
It was madness, but it is over now!
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
https://www.tiltmedia.com
