Activity › Forums › Adobe After Effects › Recall the effects name in after effects
  • Erik Waluska
    March 4, 2014 at 4:13 am
    I don’t have AE with me now so I can’t verify, but with text layers that have been renamed, if you select them and hit “Enter/Return” to rename and then “Delete” so the name is blank, and then hit “Enter/Return” again, they will revert to the original text. Not sure if that works with effects names but it’s worth a try.
    Erik Waluska
    EAWmedia
  • Graphics animator amarjit Singh
    March 4, 2014 at 10:45 am
    HI Erik,
    Thanks for the reply, but it did’t work for effects, it works for layers only. But i found another way out by going to the about tab in the effects controller, it shows the orignal name of the effect.
    Regards
    Amarjit Singh
