Activity › Forums › Adobe After Effects › Rec 709 to XYZ – After Effects vs OpenDCP vs Resolve Lite
  • Rec 709 to XYZ – After Effects vs OpenDCP vs Resolve Lite
    Posted by Daniel Raim on August 5, 2012 at 11:31 pm
    Hi everyone,
    I have a 1920×1080 24p Prores 422 HQ color corrected in Rec 709. I need to make a DCP out of it.
    I am seeing 3 ways of converting Rec 709 to XYZ:
    1. Importing the ProRes 422 HQ into After Effects and changing the color space to DCDM X’Y’Z’ (Gamma 2.6) 5900K (by Adobe) -> Export Tiff Image Sequence 16bit. In OpenDCP Version 0.0.26, unchecking XYZ conversion.
    2. Importing the ProRes 422 HQ into After Effects and exporting Tiff Image Sequence 16bit without any color space conversion. In OpenDCP Version 0.0.26, checking XYZ conversion.
    3. Use Resolve Lite to apply a 3D LUT to convert from Rec 709 to XYZ. Export from Resolve as Tiff Image Sequence 16bit. In OpenDCP Version 0.0.26, unchecking XYZ conversion.
    What’s the most accurate conversion? Is OpenDCP Version 0.0.26 XYZ conversion using a 3D LUT?
    If so, am I right to assume that OpenDCP’s conversion is superior to After Effects’ conversion?
    Lastly, how does OpenDCP’s conversion compare to Resolve’s?
    Thanks so much for your help!
    Daniel Raim replied 14 years, 1 month ago 3 Members · 3 Replies
