Rebuilding System for Vegas – Suggestions?
Posted by Ken Bennett on June 2, 2012 at 2:57 amIt’s the to upgrade my editing system. New MOBO, CPUs, RAM, graphics card and I/O interface (analog, HDMI, etc.) to maximize performance for Vegas Pro 11, After Effects and maybe a bit Premiere Pro CS5.5.
OK, give it too me. Your suggestions.
Thanks.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!John Rofrano replied 14 years, 3 months ago 5 Members · 7 Replies -
Steve Rhoden
June 2, 2012 at 3:23 amWell Ken, you can try searching the forum, you will find a
number of recommendations on this subject.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Jeff Schroeder
June 2, 2012 at 4:22 amWhat’s your budget? I have 2 systems that work quite well, very different in price range.
Jeff
2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
Stephen Mann
June 2, 2012 at 2:33 pmGo to the Videoguys website and look for their DIY specs.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
John Rofrano
June 3, 2012 at 1:46 pm[Stephen Mann] “Go to the Videoguys website and look for their DIY specs.”
That’s solid advice. I’m looking to build the Videoguys’ DIY9: It’s Time for Sandy Bridge-E. It’s a single Hex Code that should be a screamer. The thing to watch out for is that some of the newer motherboards don’t have Firewire anymore so if you are using a Firewire audio interface (like I am) or you’re still capturing HDV tape (like I am) you’ll need to purchase a separate Firewire card. 🙁
Ken, I thought you already had dual Xeon Quad Cores. The only logical upgrade for you would be Dual Hex Cores. Otherwise why upgrade?
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Ken Bennett
June 3, 2012 at 8:49 pmWhy the upgrades? You tell me? I have an aging Supermicro X7DWA MOBO with those dual Xeon 2.83 (8 core) CPUs and 16GB RAM. It has 2 PCI-Exp 16 slots and 2 PCI-X 133/100 slots and 2 PCI 133 slots. It can handle up to 64GB DDR2 RAM. I need to upgrade my graphics card from the GTX450 to a Q4000 (can this MOBO handle this card?). I need to add an I/O card for analog I/O and, between the 2 cards, be able to output Vegas to HD external monitor (HDMI). I also need Firewire for HDV tape capture and about a total of 8 USB ports. This MOBO only supports USB 2.0. I also have my RAID interface card to support 2 external RAID-5 boxes.
So, do I really need a new MOBO or can this one still survive? My goal is stability, speed and HD output.
What does Sandy Bridge give me?
THX
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures! -
Ken Bennett
June 3, 2012 at 8:53 pmOne of the reasons for the I/O interface card is due to the retirement of my VideoToaster card and SX-8 break-out box. I still do analog tape transfers.
Ken Bennett
Video Adventures
John Rofrano
June 5, 2012 at 11:51 am[Ken Bennett] “So, do I really need a new MOBO or can this one still survive? My goal is stability, speed and HD output.”
If you’re looking for stability, you may just need a new motherboard with your existing processors. That’s the problem with PC’s. Some motherboards are just flaky. All of the specs can match and they still don’t work right. I have a secret formula that hasn’t failed me yet… I buy Intel motherboards for my Intel processors. Call me crazy, but my workstation has been solid as a rock for 5 years now.
[Ken Bennett] “What does Sandy Bridge give me?”
Right now Sandy Bridge is the only architecture with 6 cores. The new Ivy Bridge has only 4. If your Xeon’s are Core 2 technology then you’ll be moving up to the faster Core i technology. There should be a significant speed boost.
The problem you have is that you already have 8 cores so you would need to build a system around two Xeon X5650’s to get 12 cores if you’re looking for more power. Unfortunately, this is older ”Westmere” technology and not Sandy Bridge.
If you want Sandy Bridge then take look at the Xeon E5-2600 series. These go up to 8 cores (so two of them would give you 16 cores with 32 threads!) You could get 12 cores (two 6 cores) using the Xeon E5-2630 which is 2.3Ghz for $612 or 2.5Ghz for $885. If you really want the latest and greatest and money is no object then a single Xeon E5-2687W 3.1Ghz 8 core will set you back $1800!!! (that’s $3600 for two of these) of course you could get a Xeon E5-2665 which is 2.4Ghz/8 cores for $1440 each.
Intel pretty much has a processor at every price point so you first should figure out how many cores you want and what you want to spend. Then select a processor at that price point, select an Intel motherboard that is recommended for that processor and only buy memory that Intel has tested and approved for that motherboard and get 2GB of memory for each core. That’s how you build a stable system (at least that’s how I do it) 😉
~jr
