Activity Forums VEGAS Pro reassemble timeline without gaps
  • reassemble timeline without gaps
    Posted by Doyal Gudgel on June 11, 2011 at 11:50 pm
    I’ve got quite a long project that has had considerable deleting and pasting events. When I delete an event say, at the start of the project I then had a lot of events that have to be moved to get rid of the blank areas if I want a continuous project. Does Sony have one command that will do that without reassembling one by one to get the project all in one piece again? I’m pretty sure I’m not the first with this problem.
    Thanks for your help.
    DG
    Hope to see you
    https://seniorobserver.blogspot.com, https://billswar2.blogspot.com
    Doyal Gudgel replied 15 years, 2 months ago 2 Members · 2 Replies
  • John Rofrano
    June 13, 2011 at 3:16 pm
    [doyal gudgel] “When I delete an event say, at the start of the project I then had a lot of events that have to be moved to get rid of the blank areas if I want a continuous project. Does Sony have one command that will do that without reassembling one by one to get the project all in one piece again?”
    Before you delete an event, turn on Ripple Edit. This will automatically move all of the events to the left to fill in the gap. Then turn it off once the gap is filled. It has several options for rippling just affected tracks, or all affected tracks and markers.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Doyal Gudgel
    June 13, 2011 at 7:49 pm
    Fantastic! Thanks
