Activity › Forums › VEGAS Pro › rearranging video clips in Sony Vegas Pro
  • rearranging video clips in Sony Vegas Pro
    Posted by Dennis Langhoff on January 12, 2009 at 5:06 pm
    The most basic question I know but can someone please tell me how to rearrange video clips? I had all my 8mm film transfered to a hard drive and unfortunately they are all out of sequence so I need to rearrange them before I do any edits ect. What would be the easiest way to do that?
    Thank You In Advance!
    Terry Esslinger replied 17 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Danny Hays
    January 13, 2009 at 3:36 am
    Are they all in one video or seperate and not in the order they were recorded?
  • Dennis Langhoff
    January 13, 2009 at 4:21 am
    Each video represents different subjects that I need to split up and rearrange so they are in sequence…it looks like if I use the split frame function that will work unless anyone has a better way….I want to get them all in sequence before I edit..adjust color ect and lastly add a music track.
    Let me repeat these are copies of 8 and super 8 movie film that I had transferred to hardrives so I can edit down to make a decent movie. After this, I have aprox 350 hrs of video tape that I also had transferred to hard drives so hopefully by then I will have this program figured out.
  • Terry Esslinger
    January 13, 2009 at 5:50 pm
    All you have to do is place your converted footage on the time line and view it (lol). As you view it have a quick finger on the s key (Split. This is where you make cuts. Make a cut at the beginning of a ‘toss-away’ section and one at the end of that section. Then highlighht that section and delete. You have not destroyed your original if you find you made a mistake you can just click grab the end of a section and stretch it out and recover what you deleted. If you have ‘auto-ripple’ enableed the spaces will even close up for you. You can then grab each section and mover them where you woul,d like.
    [Dennis Langhoff] “350 hrs” ouch
  • Dennis Langhoff
    January 13, 2009 at 6:29 pm
    Ok Will Do…now another question…What is DVD Architect Pro 4.5 that I got with Sony Vegas Pro…is it instead of or in conjunction with…which is better or what….Yikes what did I get myself into
  • Terry Esslinger
    January 14, 2009 at 5:27 am
    Vegas, as you know, is a Video editing program (NLE). DVDA is a DVD authoring program. That is where you take your movie that you edited in Vegas and author it into a DVD with (or without ) menus etc. It is also a DVD burning program though a lot of people seem to like to go to another program to burn for some reason. I have never (yet) had any problem with burning DVDs in DVDA. I even placed a BluRay video on a standard DVD disc. BR discs are outrageously expensive.
  • Dennis Langhoff
    January 14, 2009 at 3:44 pm
    Thank You! I appreciate everyones help…Here is another question…I am using the Split function to rearrange my clips and everytime I split, it leaves one frame behind …doesnt capture all frames I want..how to I correct this?
  • Terry Esslinger
    January 14, 2009 at 5:17 pm
    Don’t know that I quite understand what you are saying but if I do then just move your split over one frame! You can split frame accurate by zooming in on the time line. You can move the curser a frame at a time by using the arrow keys..
