Activity › Forums › Creative Community Conversations › Reaper and FCPX
Reaper and FCPX
Posted by Steve Connor on March 1, 2013 at 11:48 pmVery interested to see that Vordio have a plugin that will export FCPX XML to Reaper, I’m going to be trying this out on a project next week, Looks like it might be a nice, inexpensive solution for more complex audio mixes in FCPX without going to ProTools.
Steve Connor
‘It’s just my opinion, with an occasional fact thrown in for good measure”Jari Innanen replied 13 years, 6 months ago 5 Members · 7 Replies -
David Lawrence
March 2, 2013 at 2:00 am[Steve Connor] “Very interested to see that Vordio have a plugin that will export FCPX XML to Reaper, I’m going to be trying this out on a project next week, Looks like it might be a nice, inexpensive solution for more complex audio mixes in FCPX without going to ProTools.”
II’m test driving Reaper right now on a tiny project and so far I’m liking it a lot. Light, fast and easy to use with some nice UI features. Price is right too. Just wish it could import OMF natively. The only real I/O solution is AATranslator, which looks great but is a bit pricy and is Windows only.
_______________________
David Lawrence
art~media~design~research
propaganda.com
publicmattersgroup.com
facebook.com/dlawrence
twitter.com/dhl -
Oliver Peters
March 2, 2013 at 2:33 amI’ve also had very good luck going from FCP X to Audition via Xto7.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Mark Dobson
March 2, 2013 at 11:02 amHaving worked on the audio how do you then get it back into the project in FCPX? Is it a fairly straightforward exercise?
And I presume that most of you have seen this post on fcp.co – but for those who haven’t:
Oliver Peters
March 2, 2013 at 12:59 pm[Mark Dobson] “Having worked on the audio how do you then get it back into the project in FCPX? Is it a fairly straightforward exercise?”
You would have to export a mixed soundtrack (typically stereo) as a WAV or AIF and add that back as a connected clip. That’s what I’ve done using Audition, but also ProTools and Soundtrack Pro with FCP7, FCPX, Smoke and Media Composer.
– Oliver
Orlando, FL
Mark Dobson
March 2, 2013 at 6:16 pmThank’s Oliver.
Seems like the sort of process you go through once an edit has been locked down.
Oliver Peters
March 2, 2013 at 11:01 pm[Mark Dobson] “Seems like the sort of process you go through once an edit has been locked down.”
Yes. I would say that’s pretty much true of any audio post workflow. I don’t really know of any good roundtrips when it comes to the audio side of things.
– Oliver
Orlando, FL
Jari Innanen
March 14, 2013 at 8:15 pmThere is an update to Vordio:
https://vordio.net/vordio-2-0-update/
