Activity Forums Adobe After Effects Expressions Realtime Render Progress Bar
  • Realtime Render Progress Bar
    Posted by Bart Remmers on July 11, 2016 at 12:40 pm
    Hi!
    This might be a bit far fetched, but I’m going to try anyway.
    When automatically rendering a project on another machine (with multimachine rendering) it’s possible to open up the project and let it render a composition that’s already in the renderqueue. But when the project was saved showing another comp it shows that one while rendering. I’d like to build a statusscreen for the render, containing info such as ‘Render date’. I’ve found an awesome expression from Dan that makes it display the current date (if you read this, thanks a lot Dan!) I’m not sure if this sort of thing excists but I’m looking for an expression that can show the percentage of how far the current render is. This way I can have my statusscreen showing someone how far the render is in percentages, maybe even with a nice and flashy status bar. Although I’m not sure if this will work because it will be a stillscreen ofcourse, that won’t animate and maybe not even update.
    Thanks in advance.
    Bart
    Bart Remmers replied 10 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 11, 2016 at 1:20 pm
    Unfortunately, render status info isn’t available to expressions.
    Dan
  • Bart Remmers
    July 11, 2016 at 1:32 pm
    Thank you for your answer! 🙂
