Activity › Forums › Blackmagic Design › Realtime AE preview through Intensity Pro?
  • Realtime AE preview through Intensity Pro?
    Posted by Bill Paterno on July 16, 2008 at 5:06 pm
    I received an Intensity Pro a few days ago. I installed it into my Mac Pro in the 2nd PCI slot and did some test runs in After Effects. I was able to play back my RAM previews in RT for both HD and SD comps through component out.
    I then ordered an HDMI cable and hooked that up. In the interim, I moved the Intensity Pro card to the 4th PCI slot (because I read somewhere that that was the best place to install). Now I cannot get a RAM preview to play back in RT. I am not sure if this is an HDMI limitation or perhaps I need to move the card back???
    Any help would be greatly appreciated.
    Bill
    Luke Maslen replied 18 years, 2 months ago 2 Members · 4 Replies
  • Luke Maslen
    July 17, 2008 at 4:28 am
    Hi Bill,
    Connecting the HDMI cable would not cause the RAM preview of After Effects to fail. Please check if you are still able to output component analog video from After Effects. If that doesn’t work, then nor will your HDMI output. If that is the case, you could try moving the Intensity Pro card back to the slot where it was last working well, then confirm that component output works fine and then attach a HDMI display and see if that works fine.
    If you have an Early 2008 model of Mac Pro, I would recommend slot 3 or 4.
    If you have the original series of Mac Pro, shut down your Mac and place the Intensity Pro card in slot 4. Start up the Mac, go to /System/Library/CoreServices and launch the Expansion Slot Utility. Select the second PCI Express Profile, ie: x16 Lane Graphics Slot + Two x4 Lane and One x1 Lane Slots. The click the Save and Restart button. Upon restarting, check that you can see video output on your component analog and HDMI outputs.
    I hope this helps and please let me know how you go.
    Luke Maslen
    Blackmagic Design
  • Bill Paterno
    July 17, 2008 at 1:03 pm
    Luke,
    I think you have misunderstood what my problem is. I can get RAM preview through HDMI to my plasma monitor. However, its not in real time. I will try your suggestions though.
    Bill
  • Bill Paterno
    July 17, 2008 at 1:45 pm
    I just sent this to BM tech support:
    Ok. Here is the thing. I cannot get real time Hi Def RAM previews through HDMI or Component. I tested previewing a 1080i comp in After Effects with Video Preview set to Intensity Pro 1080i 59.94. When I go to preview it is only a quarter speed at the Faster setting. At More Accurate, its only 4 fps.
    I bought this card because I believed that you can watch Hi Def RAM previews on a HD monitor. So far, that doesnt seem like it is possible. I can view NTSC fine and can set up NTSC preview for a HD RAM preview, but the image is not very good.
    Is this the limitations of the card or am I missing something here??
    Bill
  • Luke Maslen
    July 23, 2008 at 1:51 am
    Hi Bill,
    SD RAM previews should play through in real time once rendered to RAM. HD RAM previews will usually be below real time even after having being rendered to RAM. 1080i50 video seems to play a lot faster than 1080i59.94 so we’re investigating why there is such a big difference in RAM preview speed between these two formats so we can try to speed it up. I expect this can be improved because it doesn’t make sense that there should be such a big difference between these two formats. This issue is currently scheduled for completion two driver releases from now.
    You mentioned that you previously saw faster RAM previews (via component output) when you used the card in a different slot so it might be worth reverting to that configuration and see if you can obtain an improvement in speed. If so, please let us know which slot and which PCI Express profile you have chosen as this will help us to investigate the problem.
    Regards,
    Luke Maslen
    Blackmagic Design
