Activity › Forums › Apple Final Cut Pro Legacy › realplayer woes
  • realplayer woes
    Posted by Ben Oliver on October 26, 2006 at 4:48 pm
    Hey guys. I have an issue, that I am sure some people here could help with.
    I have a lecture that was shot into quicktime using a firestore. The file worked fine with FCP Studio (fully updated) I successfully edited it down, made it into a dvd using compressor and dvdSP4. I then needed to render out a REALPLAYER media file. There is no wiggle room, it must be REALPLAYER, we already made them a quicktime file, which works FINE.
    I am on a dualcore g5. I installed the realplayer export, available on the real.com site. IT works fine from quicktime pro. Even tho it’s not 10.4 supported, it says failed, but the files always work..
    So I rendered out, fully, a 13gb file from the firestore files. (the firestore records in 9min bursts), this realplayer file, is out of sync. I try sorenson squeeze, and it doesnt even render out a file. (Ill save my squeeze stories for another day) I try on three different computers, using squeeze, qtpro, anything I can think of, it won’t render it in sync.
    I then took another file, shot quicktime (.mov) with the firestore, from anotehr project, it won’t render in sync.
    I then take a file that I captured from a tape, and it renders…fine.
    Any ideas here guys?
    Ben Oliver replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
