Activity Forums Adobe Premiere Pro Really WEIRD video glitch with Blur…
  • Really WEIRD video glitch with Blur…
    Posted by Michele Poggi on April 16, 2016 at 3:46 pm
    Whenever I try (with any project, even after restarts) to use on my project and any layer/file a Gaussian or Fast Blur for example…
    This happens:
    It change at every value, becoming completely random and gross, unreasonably so. It ONLY happens with HORIZONTAL or “both” blurs. Not with the Vertical one.
    I honestly don’t know where to look for a solution with this.
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: sn*******@***il.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Jerry Michaels replied 10 years, 3 months ago 4 Members · 4 Replies
  • Michele Poggi
    April 16, 2016 at 8:05 pm
    Sadly no answer up until now, so it means it actually IS something rare or new.
    I tried everything and I DID find something: the GPU Acceleration (Open CL) is the cause of this, but I’m wondering if there is any way to keep that advantage without destroying my chance to blur layers.
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
  • Duke Sweden
    April 17, 2016 at 2:53 pm
    Hi Michele, I don’t know if this could be the problem, but I’ve read other posts where having two clips one above the other in the timeline will cause problems with certain effects/plugins. I see in the picture that is the case here. Have you maybe tried turning off the upper video track to see if the problem goes away?
  • Tero Ahlfors
    April 17, 2016 at 4:01 pm
    [Michele Poggi] “Sadly no answer up until now, so it means it actually IS something rare or new.
    Can we start with you telling the computer specs, footage formats, timeline/preview file settings?
    [Michele Poggi] “I tried everything and I DID find something: the GPU Acceleration (Open CL) is the cause of this, but I’m wondering if there is any way to keep that advantage without destroying my chance to blur layers.
    There’s a chance your GPU isn’t officially supported.
  • Jerry Michaels
    April 18, 2016 at 10:28 am
    Do you happen to have an AMD graphics card? I have the same problem, and I have an AMD R9 380 card in my system, which is not on Adobe’s supported GPU list, but is practically identical to R9 285, which is on the list. Anyway, Adobe is well known for both updating this list much too late and being not very friendly with AMD/OpenCL but favoring CUDA instead (although I don’t know if CUDA gets any speed advantage, have never had the chance to test and found no comparisons on the web either).
