Activity Forums Adobe After Effects Really weird AE Error!?!
  • Really weird AE Error!?!
    Posted by Andy Atkins on January 22, 2009 at 4:32 pm
    What causes this:
    CHECK OUT THE LINK FOR A PICTURE (SCREEN GRAB)
    https://www.flickr.com/photos/aoav/3218278326/
    Anyone know what this is? I just got this massive interface error in AE CS3. All the other apps work fine. Photoshop, Flash, Word… you name it they work fine. I was working in trapcode, then my screen went blank. I had to replace my graphics card. And I also can’t use my DVI port on my monitor anymore… WEIRD? Can you help?
    Heres a step by step of what happened
    I was working in AE CS4, with 3D Stroke and particle.
    Then my system locked up, my screen went blank. I had to force restart the computer. When I tried to get it back up, no signal to my screen. I tried two other monitors and cables. No luck.
    I replaced the GFX card, now it works, but only in VGA not DVI.
    I also re-installed CS3 and all other progams work. Flash, PS, Ill, all, but AE. it is sooo weird.
    Please help.
    andy
    AE-Error
    Andy Atkins replied 17 years, 7 months ago 2 Members · 2 Replies
  • Jan Sherlink
    January 22, 2009 at 5:04 pm
    That’s not an AE error,
    it’s a problem with your video-card or drivers.
    Try disabling your Open-GL plug-in and startup AE,
    if it works… it’s certainly a problem with your video-card/drivers.
    It means Open-GL/3D if knocking out your card.
    Update your videocard-drivers,
    but I think your card might be fried 🙁
    cya,
    Jan
  • Andy Atkins
    January 22, 2009 at 7:46 pm
    Yeah thats what I thought, but I replaced the GFX card. I even switched brands. But I like the OpenGL idea. I will see.
    andy
