Activity › Forums › Apple Final Cut Pro Legacy › Really Strange Capturing Problem…
  • Really Strange Capturing Problem…
    Posted by Erik Carlson on November 12, 2008 at 12:29 am
    So I’m trying to capture some footage today and ran into a really bizarre problem…the capture ends at 9 minutes, 25 seconds and 15 frames and tells me that I don’t have enough harddrive space left (which is nonsense cause I have over 100gigs available and am only trying to capture 50 minutes of normal DV footage).
    I’ve tried a few different tapes and still exact same problem pops up at the exact same point.
    I don’t have any limits set for capturing in the settings.
    I’m using Final Cut 6.0.04…the newest version.
    Mark Suszko replied 17 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • Chris Borjis
    November 12, 2008 at 12:45 am
    what happens if you try to just capture the last minute or so?
    same problem?
  • Peter Wiggins
    November 12, 2008 at 12:51 am
    Ok a wild guess, but have you got your scratch disk formatted for Windows?
    Peter
  • Erik Carlson
    November 12, 2008 at 2:13 am
    Nope…not formatted for windows…I’ve been using this drive for nearly a year now for editing and have never had a problem…this is new.
  • Erik Carlson
    November 12, 2008 at 2:15 am
    I don’t know, I haven’t tried that.
  • Tom Daigon
    November 12, 2008 at 4:06 am
    Does this sound like the problem folks had with Quciktime 7.2 (I think) where Apple had implemented
    the copy protection function that stopped users from making any Quicktime files that were 10 minutes or longer?
  • Wes Koetje
    November 12, 2008 at 4:55 am
    I have seen that error, when I have the limit capture now button checked in the system prefs, but that is the only time I have seen it with ample disc space.
  • Erik Carlson
    November 12, 2008 at 5:49 am
    Yeah, I don’t have that button checked so I have no idea what’s going on…I mean, I’ve been using Final Cut for YEARS and this just suddenly came out of left-field, so to speak, today.
  • Mark Suszko
    November 12, 2008 at 5:33 pm
    Do you perhaps have time code breaks with different hour numbers that can trick the system into thinking you’re asking for several hours of recording?
