Activity Forums Adobe Premiere Pro Really need advice on music video editing technique
  • Really need advice on music video editing technique
    Posted by Sam Alderson on June 2, 2014 at 12:56 pm
    Hi there,
    I am editing a music video and would love (need) some advice on the most efficient way to do this.
    I have three different types of shots, one for each of the three people in the video. Then each person has 3 different costumes, and each costume has 4 different angles.
    So thats 3 people x 3 costumes x 4 angles = 36 shots
    I have gone through and edited out anything I can’t work with from these shots and am left with 36 clips, all synched, and cut up to leave just the good bits.
    I have attached a screenshot of my sequence so you can see what it looks like (the three different colors represent the three different people). I am using Premiere Pro CS4 by the way.
    I want to edit these clips in a fast-paced way similar to Technotronic’s Pump up the Jam
    https://www.youtube.com/watch?v=9EcjWd-O4jI
    What is the most efficient way to go about this? I was going to add another video track to the sequence and just cut and paste into it, but seeing as there are so many clips to compare and it will be so many quick shots I was wondering if this is the best way.
    Thank you so much if you can help
    Sam
    Jonan Grobler replied 12 years, 3 months ago 2 Members · 1 Reply
  • Jonan Grobler
    June 2, 2014 at 2:05 pm
    It sounds like this is what you’re looking for:
    https://helpx.adobe.com/premiere-pro/using/create-multi-camera-source-sequence.html
    I used to use the same function in Final Cut Pro back in the good ole days when everyone wasn’t hating on FCP, but I haven’t tried the Premiere Pro function yet. Should be what you’re looking for.
    Be aware that you might find this method slows down your computer a whole lot, as it’s searching through four or more shots simultaneously. You might find the copy/paste method to be faster.
    Jonan Grobler
    Editor/Motion Graphics
