Activity › Forums › Maxon Cinema 4D › Realflow meshes not visible in Cinema 4D 11.5
  • Realflow meshes not visible in Cinema 4D 11.5
    Posted by Javier Lopez on July 24, 2010 at 10:30 pm
    Hello,
    I had exported the meshes from Real Flow 5, based on a tutorial, but when importing to Cinema 4D 11.5 they are not visible, any possible solution?.
    Thanks in advance for the responses.
    Randy Johnson replied 16 years, 2 months ago 2 Members · 1 Reply
  • Randy Johnson
    July 25, 2010 at 10:57 am
    Did you save in realflow after you simulated?
    Did you export all from realflow and try that?
    Are you importing the right .bin from the mesh folder in the realflowfile group using the realflow SD importer?
    Is it scale issue? Is it too small to see like a lightwave file generally is?
    What tutorial did you watch?
    /randy
