Activity Forums Apple Final Cut Pro Legacy real time video with aja kona LH
  • real time video with aja kona LH
    Posted by Razamataz on August 25, 2006 at 3:09 pm
    What I am trying to do is capture from an analog input. I am using the kona 8bit to dv easy set up before creating a new sequence so the settings are applied. However when I bring my captures onto the timeline, it forces me to render everything, even when there are no filters or transitions. How can I get this to play back in real time using the kona?
    Mark Maness replied 20 years ago 5 Members · 6 Replies
  • Bob Vick
    August 25, 2006 at 3:14 pm
    Make sure that the Sequence settings and the Capture settings match.
    b
    Bob Vick sr promo guy @ ch3 wwmt tv, kalamazoo, mi
  • Razamataz
    August 25, 2006 at 3:26 pm
    I have tried that already but that didn’t make any difference.
  • Jeremy Garchow
    Make a new sequence before placing the clips in your timeline.
  • Bob Vick
    August 25, 2006 at 3:32 pm
    Was going to say the same. Changing the settings to your sequence after you have clips on it won’t work. You must make the settings change and then create the sequence.
    b
  • Debe
    August 25, 2006 at 3:34 pm
    If you changed the Sequence Settings in the A/V Settings, that applies only to any new sequences created since you changed the settings. To change the settings for a sequence already created, select the sequence in the Browser, and hit CMD+0 (zero). The changes you make there apply only to the sequence you selected.
    debe
  • Mark Maness
    August 25, 2006 at 6:44 pm
    Check to see if your sequence is DV. I bet its set to 8-bit, of which, would be a problem for you and you would have to render everything.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
