Activity › Forums › Creative Community Conversations › Real PC Requirements for Adobe CS4 Production Suite?
  • Real PC Requirements for Adobe CS4 Production Suite?
    Posted by Gerry Bayne on December 8, 2009 at 9:37 pm
    So I’m new-ish to video editing and I need to spec out a machine that will use Adobe CS4 Production Suite, including After Effects, Premiere Pro, and my own Adobe Audition, often running together. I looked at the minimum system requirements on the Adobe site but have some legroom to get a good system. I’d like to stay under 1,700.00 if possible. I’ll be shooting on a Vixia HF10 in HD onto SDHC cards. I’ll want to do graphics and good editing and some post-production effects/color correction. I’m using the system below as my starting point. Could you guys tell me what I realistically need in terms of memory and computing power? Thanks so much.
    My starting point is: HP Pavilion Elite e9290f Desktop PC NEW ($1,179.00)
    Processor: Intel Core i7-920 Processor
    Memory: 9GB
    Memory speed: PC3-8500 DDR3 SDRAM memory (3x2048MB and 3×1024 for ultimate performance)
    Total memory slots: 6 DIMM (240-pin, DDR3) (occupied)
    Maximum memory expansion: Expandable to 24GB
    Graphics card: Nvidia Geforce GTX 260 graphics card with 1.8 GB dedicated graphics memory, 2 DVI ports and support for Microsoft DirectX 10.1
    Hard drive: 1 Terabyte 7200RPM Serial ATA hard drive
    Tim Kolb replied 16 years, 9 months ago 2 Members · 1 Reply
  • Tim Kolb
    December 10, 2009 at 1:45 am
    8 GB RAM is minimum…you’ll find that 16 GB is better.
    64 bit OS (to access that extra RAM above 4 GB)
    BIG proc…4 core minimum…8 core is far better.
    Serious display card helps…a Quadro is helpful.
    The key idea is that CS4 with its cross-application data-slinging, really NEEDS resources. Adobe has traditionally rated their software for minimum runnability when most of us are using these suites with 3 apps open running full out just bringing even the stiffest systems a stress-test.
    TimK,
    Director, Consultant
    Kolb Productions,
