Activity Forums Maxon Cinema 4D real flow SD exchange
  • real flow SD exchange
    Posted by Jonas Espinoza on April 2, 2009 at 7:31 pm
    having trouble with SD reimport back to C4D from realflow
    I export the shapes, do the rigid body physics. update the SD file. I use the SD import plug in and point it to the SD file. the only thing is the animation is not comign back into c4d. is there anything else to this workflow i might be missing?
    thanks
    Jonas Espinoza replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
