Activity › Forums › Adobe After Effects › Reading XML using expressions
  • Reading XML using expressions
    Posted by Frank Lima on June 13, 2012 at 1:04 am
    I’ve been trying to read in an XML using expressions. I saw in the forum that it IS possible, through this link: https://forums.creativecow.net/thread/227/20842
    However, when I implement the code, it gives me an error that says: class ‘global’ has no property named ‘myXmlFile’
    the code is here:
    var fileOK = myXmlFile.open("r");
    if (fileOK){
    var myXmlString = myXmlFile.read();
    var myRoot = new XML (myXmlString);
    myXmlFile.close();
    I notice that there is an object named ‘myXmlFile’ now how do I create it? I know var fileOk is an object that does something with ‘myXmlFile’ but HOW do I create the var for myXmlFile? and what is “r” ? to read?
    Sorry, new to javascript. It’s so different from other languages.
    Frank Lima replied 14 years, 3 months ago 42,934 Members · 1 Reply
  • Frank Lima
    June 13, 2012 at 1:35 am
    If I create the var such as:
    var myXmlFile = new File(testXMLPath);
    with:
    testXMLPath = “happy.xml”;
    It throws an error and says: “File does not have a constructor”
