Activity Forums Adobe Premiere Pro Reading timecode data from an audio track
  • Reading timecode data from an audio track
    Posted by Deleted User on September 22, 2011 at 8:47 pm
    Can Adobe Premiere pro 5 or 5.5 do the folowing with my work-flow.
    The timecode audio is being generated from a Time Code Generator and fed into camera audio Canon 5d mk2.
    The BWF WAV audio recorder is also receiving the same timecode as the camera.
    The audio recorder is recording the audio at 96,000khz 24bit stereo as master audio.
    So the desire would be to bring in the video file which has timecode in the audio channel from Timecode generator, then bring in the separate timecoded BWF files from the audio recorder, then autosync in Premiere to the video timecode audio track, to the audio from BWF.
    Similar to what Avid Media Composer video shows. I will be using the same Time Code Generator and Tascam HD P2.
    https://www.youtube.com/watch?v=U6m1vNTeRso
    Leo
    Alex Udell replied 14 years, 11 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    September 22, 2011 at 9:39 pm
    Premiere Pro only reads timecode from BWF files. It cannot read SMPTE audio timecode.
    You’re looking at a tool like auxTC that will read audio timecode then convert/embed it into a Quicktime TC track (maybe someone else can chime in to confirm 100% that PPro reads a Quicktime with embedded timecode, I don’t have a file to test at the moment).
    Another tool is Plural Eyes which matches up two-system audio based on the audio fingerprint itself. If the audio quality is decent from both systems I’ve used it to 100% accuracy. I’ve also seen it used on the last feature I worked on so it’s relatively common in the industry. My big tip is that you need to sync your scenes before you edit. It will also sync additional cameras based on audio for multicam edits.
    – Angelo Lorenzo
    https://FilmsFor.Us Helping you sell your film online
  • Deleted User
    September 23, 2011 at 9:13 am
    Hello Angelo,
    Thanks for the reply, yes I have been looking into auxTC plugin and that seems the best solution to get the timecode from the audio and put into the Quicktime as timecode. I will have to test with doing this and Premeire pro readingthe timecode from the Quicktime video file.
    I would rather use the Timecode to sync from the camera and audio recorder, Dualeyes is very slow as I have been testing it for the past few months. Even with good sound levels in camera and the recorder it took hours scanning the audio files and half the time in failed or synched 1 clip only.
    Thanks for the advice will tets out the auxTC plugins.
    Leo
  • Alex Udell
    September 23, 2011 at 1:39 pm
    if the aux time code could somehow be exposed as an audio track, couldn’t the new tools in cs5 be used to sync then?
    Alex
