Activity Forums VEGAS Pro Reading Close Captioning when importing
  • Reading Close Captioning when importing
    Posted by Linda O’connell on January 13, 2015 at 9:39 pm
    I am using Vegas 11.
    I am importing old home movies…mostly these files are MPEG 2. But whenever I import these it takes forever because it also says it is “Reading Close Captioning”
    Is there an option so it doesn’t do that on importing? I don’t ever use close captioning.
    Mike Kujbida replied 11 years, 8 months ago 2 Members · 3 Replies
  • Mike Kujbida
    January 14, 2015 at 1:44 pm
    You need to go into the Internal Preferences in Vegas. Do this by holding down the Shift key and then go Options – Preferences. Click on the Internal button at the top right. Once in there, type closed in the search bar at the bottom, double-click and change TRUE to FALSE in the Value box, press OK and you’re done. Restart Vegas and you won’t get that message any more 🙂
  • Linda O’connell
    January 14, 2015 at 5:30 pm
    You are awesome. Thanks! 🙂
  • Mike Kujbida
    January 14, 2015 at 5:47 pm
    You’re welcome Linda. Glad I could help.
