Activity Forums Apple Final Cut Pro Legacy RE: Video Shifting
  • RE: Video Shifting
    Posted by Larry Bell on January 17, 2006 at 10:40 pm
    I have video and graphics that shift during video transitions. I have two video clips ( I have used jpegs as well) with a cross dissolve in the middle on v1. I also have a title on v2 through title generator and lower 3rd. This also has a video transition with cross dissolve in. The transition from video clip to clip last 30frames. About 60frames later my transition for the title on v2 comes in. The video shifts as the title comes in. I move the title down and the video shifts at that point. I have tried a more complex composite that had a lot more elements and the video shifted as well. Any help?
    Larry Bell replied 20 years, 8 months ago 3 Members · 4 Replies
  • Tom Wolsky
    January 17, 2006 at 10:48 pm
    Are you looking at the rendered output on a video monitor?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Arnie Schlissel
    January 17, 2006 at 11:24 pm
    Further to what Tom said, check your timeline settings. It sounds like you’ve got the video processing set to RGB when you should be set to YUV.
    Arnie
    https://www.arniepix.com
  • Larry Bell
    January 17, 2006 at 11:59 pm
    Yes, this is the rendered output on the monitor and on the display.
  • Larry Bell
    January 18, 2006 at 1:42 pm
    Tried the RGB and YUV output. All settings are set to 8bit YUV rendering. Still got a shift. One other thing that I tried was to use Boris 3d title instead of using lower third, and that made a difference. Also using lower third with a drop shadow mad a shift. Without the drop shadow, there was no shift. Using Boris with the drop shadow there was a slight shift but not as noticeable as the other. I’m still getiing a slight shift though. Should I reinstall the software?
