Activity Forums Adobe Premiere Pro re using timeline renders in upper secuences
  • re using timeline renders in upper secuences
    Posted by Glen Perez on December 10, 2009 at 5:36 pm
    hi, im in a proyect where we use adobe premiere, we use secuences in premiere that conform the big edit at the end, so i render the individual timelines so that the bar is green, and then those secuences gets “precomposed” in another secuences, but the thing is that i have to render the timeline again…
    is there any way to preserve the renders that have been already done? thanks
    Ann Bens replied 16 years, 9 months ago 3 Members · 4 Replies
  • Ann Bens
    December 10, 2009 at 6:00 pm
    Nope, renders dont get transfered to the nested sequence.
  • Glen Perez
    December 10, 2009 at 6:13 pm
    GRRRR and is there any workaround for this?
  • Phocas Kroon
    December 10, 2009 at 11:39 pm
    There is only a need to render if you want to export the movie back to your camera. In that case render only the final sequence.
    If you export the movie to a file the rendering is done during export. So no need to pre-render.
    Phocas Kroon
  • Ann Bens
    December 11, 2009 at 9:08 pm
    Using preview files makes encoding much faster but can cause quality loss, due to only one cycle of encoding.
    Best is to use Max Render Quality, needs lots of RAM and takes a lot of time.
