Activity Forums Boris FX Re: Using BCC5 Open GL lens flair in FCP/Motion
  • Re: Using BCC5 Open GL lens flair in FCP/Motion
    Posted by Adrian Charles on November 8, 2007 at 3:02 pm
    Peter,
    Sorry it has taken me so long to reply to your post. I have tried the Bcc5 open GL lens flair on a
    G5 dual 2.7 PowerPC and a Two 3.0GHz Dual-Core Intel Xeon Mac Pro. both produce the same result.
    When a lens flare is applied in a Motion project, (4:3 aspect ratio) it has circular light rings which is what you would expect. if the same Motion project is placed on a 4:3 FCP timeline the rings appear oval shaped, which is not what you would expect. I have a screen grab and a motion project l could send to you if you let me have your email address.
    Great product by the way!!
    regards
    Adrian
    Peter Mcauley replied 18 years, 10 months ago 2 Members · 3 Replies
  • Peter Mcauley
    November 9, 2007 at 4:49 pm
    Hi Adrian,
    Apologies for the delay in getting back to you on this – I’ll follow your steps and see if I can reproduce the result that you are seeing and if so I’ll see if there is a solution that I can arrive at that will generate the result that you are looking for.
    Stay tuned.
    Cheers,
    Peter.
  • Peter Mcauley
    November 9, 2007 at 5:34 pm
    And by the way, here’s my email address:
    peterm@borisfx.com
    But don’t try to send anything larger than a couple of megs as it will be rejected by the server. yousendit ftp is best for that.
    Cheers,
    Peter.
  • Peter Mcauley
    November 9, 2007 at 5:42 pm
    Okay so I followed the steps as you described them and can’t reproduce the error that you are seeing. I used the Lens Flare Advanced, with the 16:9 option disabled and whether I apply it in Motion or in FCP the result is identical – the lens flare is perfectly round and without distortion. Are you using the FxPlug version of the filter?
    Cheers,
    Peter.
