Activity › Forums › Adobe After Effects › RE: The Open Recent Projects in the File Menu
  • RE: The Open Recent Projects in the File Menu
    Posted by David Demarco on August 24, 2005 at 2:32 pm
    I have a simple question in regards to the Open Recent Projects in the File Menu. My list has become rather long and I was wondering if anyone knows how to either clear the list completely or remove projects from it. It’s not causing any problems, AE works fine. I just would like to reduce the size of the list or just clear it completely when I need to. Thanks
    Steve Roberts replied 21 years, 1 month ago 2 Members · 5 Replies
  • Steve Roberts
    August 24, 2005 at 3:53 pm
    You could probably edit the preferences.txt file … but do so at your own risk, having saved a copy first.
    Sorry, I don’t know of a menu-type command to purge the list.
    Steve
  • David Demarco
    August 24, 2005 at 7:15 pm
    Thanks Steve. Where would I find the preference.txt file. I did a search on my hard drive and did not find it, plus I look through the AE folder and I did come across it, but I could be looking in the wrong place.
    David
  • Steve Roberts
    August 24, 2005 at 7:54 pm
    It seems to be a hidden file …
    c:-Documents and Settings-yourName-Application Data-Adobe-After Effects-Prefs
    (COW don’ do no backslashes)
    Steve
  • David Demarco
    August 24, 2005 at 9:36 pm
    Thanks Steve. I found the file and, after making a backup, will see if I can make the changes I desire.
  • Steve Roberts
    August 24, 2005 at 9:40 pm
    A backup is good because if the prefs are lost, you’ll lose any render & output module presets that you’ve created. Ugh.
    BTW, Adobe doesn’t support our editing the prefs. Just so you know. 🙂
    Steve
