Activity › Forums › Adobe Photoshop › Re-sizing issue when exporting to PDF
  • Re-sizing issue when exporting to PDF
    Posted by Chris Kennedy on March 19, 2012 at 6:48 pm
    I am currently trying to create a pdf from a Photoshop file with layers. An easy task by all accounts, but when I do so using save as PDF no matter what the settings the file re-sizes the dimensions. my original file is 525×300 pixels, 72 dpi. The export from Photoshop is usually are 150 pixels larger. I attempted to increase the dpi and mess with the compression settings in order to get an end result that closely resembled my start size, but once I combined the pdf files together it ended up larger again.
    I have also attempted to use bridge and another pdf creator (with imported jpgs) but have returned with similar results. I am sure this is probably a settings issue somewhere that I am just failing to notice, but I was unable to find any information specifically on this. Thank you for any and all assistance.
    Chris Kennedy replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
