Activity › Forums › Apple Final Cut Pro Legacy › Re-size Scren to 100 percent
Posted by James Mulryan on June 13, 2007 at 5:17 pmDoes anyone know the keystroke for re-sizing the screen from say 25 percent to full screen and then back again?
Thanks in advance.James Mulryan replied 19 years, 3 months ago 2 Members · 4 Replies -
Colin Mcquillan
June 13, 2007 at 5:22 pmapple – to shrink, apple + to grow (both in 25% increments), shift Z to “fit to window.” applies to whatever window is active, being it viewer, timeline….
Colin McQuillan
Vancouver BC -
James Mulryan
June 14, 2007 at 12:10 pmColin:
Thanks for the great tips. Still have one question though, these functions fill the grey frame, but what if you want to resize the frame, instead of having to drag the frame handle in the bottom right corner?
Colin Mcquillan
June 19, 2007 at 12:24 amYou could set up custom window size settings and add them to the bar just above the timeline for easy access (where the snap and link buttons live)
Resize the windows how you want them, then go window -> arrange -> Save Window Layout, save and name, then right click on the bar just to the left of the snap and link buttons, select “show button list”, drop down the “window Menu” list and select the custom window set-up you have just made and voila, you have one click buttons that will resize all the windows to your pre-set.
I have a bunch of different configurations set up in my quick-bar for various purposes,, just dont forget to also add the “standard” so you can quickly get back to normal window set-up once you are done with the custom set-up
“ctrl U” works even faster to resize all windows back to normal as-well
“Shift U” and “alt U” will also open up custom arrangement 1 and custom arrangement 2 respectively.
Colin McQuillan
Vancouver BC
